RETIRED
Joe Bob's Avatar
Get one made by Lucas, everything they make sucks. But they burn, smoke and blow fuses....
2012 ML350 3.0 Turbo Diesel
Old 07-27-2017, 05:41 AM
Shaun @ Tru6's Avatar
What Hugh said also. yowsa.
annnd...if you are using that room as a spray booth, don't you want to do a Dexter Morgan and cover all the walls with plastic so the LL doesn't take a chunk of your security deposit? I say this after spending three days painting a place, when it should have taken only one. There was a lot of staining and wax candle buildup in the paint.
you mean like this?
Tru6 Restoration & Design
Old 07-27-2017, 10:48 AM
Thanks to Scott Douglas, the fan in the cardboard window worked perfectly. When I make a permanent version I will mount 2 fans but one is probably sufficient. I did these door handles this morning so very little continuous paint but the room was completely clean at all times.
Note all of the flaws but the surface is like butter. I’ve found that you have to coat them to expose flaws better, then sand and fill as needed and shoot again. Either that or just ice with filler and spend a day sanding.
Doing the backs and barrels of Torque Thrusts next, that will be the true test of 1 or 2 fans.
Old 07-27-2017, 10:55 AM
T77911S's Avatar
take the blade off and flip it over.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-28-2017, 05:22 AM
Works perfect as is. Did the backs and barrels of these Torque Thrusts yesterday, a lot of paint coming out of the gun. Fan did a good job pulling paint out of the room but I'll put another one on top of it when I make a permanent version with sheetmetal.
Old 07-28-2017, 05:25 AM
What did you do the handles? Just paint and clear?
Old 07-28-2017, 06:42 AM
Just Cerakote.
Old 07-28-2017, 06:43 AM
