Shaun @ Tru6's Avatar
Want to make this fan run backwards
Any idea on which wires I switch? No pun intended.
I want to make it a sucking fan vs. a blowing fan.
Tru6 Restoration & Design
Old 07-26-2017, 10:46 AM
Jolly Amaranto's Avatar
Some AC motors are difficult to reverse. If the fan is on a pole stand, the blades are bent to be efficient rotating in only one direction. If possible, just rotated the whole fan housing 180°.
Old 07-26-2017, 11:00 AM
The Unsettler
stomachmonkey's Avatar
Just turn it around?
"I want my two dollars"
"Brandon Won"
Old 07-26-2017, 11:06 AM
Bill is Dead.
cashflyer's Avatar
Old 07-26-2017, 11:15 AM
How come you get the easy ones ?
Old 07-26-2017, 11:16 AM
Detached Member
Hugh R's Avatar
You'll have to turn it around, a fan running backwards doesn't pull air due to the shape of the blades.
Hugh
Old 07-26-2017, 11:33 AM
This. It will mostly make noise.
Old 07-26-2017, 11:42 AM
Detached Member
Hugh R's Avatar
Originally Posted by peteremsley View Post
mount the blade backwards?
That would probably work.
Hugh
Old 07-26-2017, 11:45 AM
I made a dedicated painting room for Cerakote. Has a big sliding window that I put the fan in to blow out. As a 6100 CFM fan, I thought it would do a decent job for an 8x10 room but it just doesn't pull enough air.
Doing a little research I found that exhaust fans run anti-clockwise to regular fans so thought it was worth a try.
I'm also wondering if 3 feet of open window above the fan also contributes to it not working as well as I need. Door open/closed has no effect.
Old 07-26-2017, 11:47 AM
Your open window is killing it.
Make sure the only place it can draw air from is the room itself.
Scott
'78 SC mit Sportomatic - Sold
Old 07-26-2017, 12:12 PM
Home of the Whopper
6100 cfm?
3 phase?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 07-26-2017, 12:21 PM
Agreed. I flipped the fan blades and it didn't do much using a paper towel as a draw indicator.
Will get some lauan and see what that does.
Old 07-26-2017, 12:32 PM
Originally Posted by BK911 View Post
6100 cfm?
3 phase?
20 in. High-Velocity Floor Fan-SFC1-500B - The Home Depot
It blows very strong. Just hasn't sucked yet.
If it blows strong it is moving air. You just have to make it so the air it moves comes from the right place and goes to the right place instead of reverting around the window.
Brent
Old 07-26-2017, 12:43 PM
pete3799's Avatar
I can't make up my mind whether this thread blows or sucks.
Pete
79 911SC RoW
Old 07-26-2017, 03:09 PM
Band.
Yep no air escaping around the fan. That's why a box shape fan is a little easier if you're not doing something permanent.
Also try to make the opening for the air entering the room smaller than the diameter of the fan (assuming you are able to plug up the rest of the window). It'll get a higher velocity through the room.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 07-26-2017, 03:25 PM
I put the fan blade back on correctly and cobbled this together quickly, fan mounted in Al angle and cardboard taped on.
Doing some door handles and backs of Torque Thrusts tomorrow, looking forward to seeking how it works.
Old 07-26-2017, 03:42 PM
Detached Member
Hugh R's Avatar
Cerakote seems to have an active ingredient (the carrier solvent) called parachlorobenzotrifluoride (70%+ of the mixture) , which has a lower explosive limit (LEL of 0.9%) and an upper explosive limit of 10.5% in air. This was just a quick search, but you may want to consider an explosion-proof rated fan. Also supplied air seems to be recommended, not respirators.
https://thechemco.com/chemical/parachlorobenzotrifluoride-pcbtf/
Hugh
Old 07-26-2017, 04:14 PM
^^^ This is why Hugh gets paid the big bucks.
Your description of what you're doing isn't very clear, I assume you have an air intake into the room as well, correct? If not, then that's your problem.
Old 07-26-2017, 05:55 PM
You do not have permissi
john70t's Avatar
What Hugh said also. yowsa.
annnd...if you are using that room as a spray booth, don't you want to do a Dexter Morgan and cover all the walls with plastic so the LL doesn't take a chunk of your security deposit? I say this after spending three days painting a place, when it should have taken only one. There was a lot of staining and wax candle buildup in the paint.
Old 07-26-2017, 06:10 PM
