RETIRED
Joe Bob's Avatar
Set up, Mercedes SUV Towing questions
I just bought an ML 350 Diesel. Looking to retrofit a tow hitch and have questions on the wiring needs. I am hearing that aftermarket kits are not optimal and I need a wire kit from Mercedes.
Can someone give me some BTDT insight?
2012 ML350 3.0 Turbo Diesel
Old 08-26-2017, 07:53 AM
Information Junky
island911's Avatar
Pretty sure it will throw codes if you tie directly into the brake lights and turn sigs. (wrong resistance detected by computer)
Old 08-26-2017, 07:56 AM
RETIRED
Joe Bob's Avatar
U haul quoted $396 installed with their wiring kit. Class 3 with drop hitch and 2" ball.
Old 08-26-2017, 08:24 AM
Seahawk's Avatar
I use this site fr 560SL questions.
PeachParts Mercedes ShopForum - Powered by vBulletin
They have an ML section.
Good luck. Trailer can be a *****.
1996 FJ80.
Old 08-26-2017, 08:34 AM
weekend wOrrier
I just installed a towing wiring harness on my volvo (yesterday).
I don't know if this applies to mercedes or not.
The kit I got (from e-trailer) powers the trailer lights from a separate power supply that feeds off the battery. The kit taps into the original wiring not as a power supply, but more as a relay trigger to activate the 12v power supply, so no real current draw comes off of the original harness. The volvo system is pretty finicky for resistance, and this kit has not set off any warnings so far, so at least for me, it worked. Perhaps mercedes is more finicky.
ps- I was originally reluctant to buy an aftermarket kit for the volvo, but etrailer had an installation video on youtube for my exact car, so I knew it had been done (and nobody burst into flames). Perhaps they have a merc. equivalent.
edit- mine was a curt too (like post below)
Old 08-26-2017, 08:58 AM
Powered relays for my e350 wagon from Curt have worked fine with no warnings.
Old 08-26-2017, 09:37 AM
I put 200K miles on a 2001 ML430. Back than, you had to buy OEM wiring and hitch, as it affected the SRS when hitch was used.
1972 911T/S MFI Survivor
Old 08-26-2017, 06:16 PM
RETIRED
Joe Bob's Avatar
U Haul uses the inductive wiring, offers a warranty....so is 400 a fair deal?
Old 08-26-2017, 07:49 PM
Formerly bb80sc
Vipergrün's Avatar
I equate uHaul to JiffyLube, and would personally not let either touch my vehicles. I'd at least find an independent trailer/hitch company. That said, based on prior hitch installations, $400 sounds fair
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 08-28-2017, 02:43 PM
Unregistered
sammyg2's Avatar
https://www.etrailer.com/vm/Mercedes-Benz/M-Class/t1
even has instructional video.
Old 08-28-2017, 03:24 PM
enzo1's Avatar
How do you like that M-class?
76' 911s Signature Edition
Old 08-28-2017, 05:52 PM
RETIRED
Joe Bob's Avatar
Love the ride....all the bells are coolio. The Voice command/navigation. Not so much.
Old 08-28-2017, 07:58 PM
What model year?
I have a 2000 ML430 (W163). There is a factory 7-pin trailer wiring harness that plugs into the vehicle wiring harness. Be sure to check the main fuse box. There is a specific fuse for the trailer harness.
The factory hitch is a "bolt-in" installation. Remove the bumper cover ... four bolts ... replace the cover.
Old 08-28-2017, 10:28 PM
RETIRED
Joe Bob's Avatar
2012......$22K with 60K miles. Smoking deal per my research. White with tan leather, 3.0 turbo Diesel.
Gotta part number and other stuff? I just upgraded some iPod/phone cables and purchased some DEF since it's a Diesel. But having a hard time finding trailer wiring info....I guess I can call the Merc dealer in Denver. Prolly owned by Elway....
Old 08-28-2017, 10:35 PM
RETIRED
Joe Bob's Avatar
For schitzle and giggles, I called the dealer. $9K and they won't sell just the wiring.......
Old 08-29-2017, 12:38 PM
Halm's Avatar
FWIW, it is about $2k for my Cayenne at a dealer.
'17 Cayenne
Old 08-29-2017, 04:26 PM
Can you find one at a parts yard from a wrecked one?
Old 08-29-2017, 09:27 PM
RETIRED
Joe Bob's Avatar
Been cruising the CL ads, nada.....not in a hurry. Will rent a box trailer sometime before the weather turns and get my crap in San Diego.....
Old 08-29-2017, 09:29 PM
RETIRED
Joe Bob's Avatar
I went to the site Seahawk recommended....not much action over there. So, has anyone done a performance chip on these turbo diesels?
Also, Sammy recommended etrailer. The wiring and hitch/drop and 2 inch ball is around 65 bucks cheaper than the installed price at UHaul....with warranty I may just let them do it.
Old 08-31-2017, 07:28 PM
