Information Overloader
Quick bolt question:
I want to extend the bolts exiting the rear of my camper. They are fiberglassed in and threaded on the end to receive the lug nuts for the spare.
Any simple suggestions not involving welders, structural changes to the camper, explosives or nukular material?
Old 10-07-2017, 10:06 AM
Coupling nuts.
Old 10-07-2017, 11:00 AM
Thank you!
Old 10-07-2017, 11:12 AM
wdfifteen's Avatar
Yep. It's called a coupling nut. They have them at Lowes and HD
Old 10-07-2017, 01:48 PM
Almost Banned Once
sc_rufctr's Avatar
But will the spare's lug nut holes fit over the coupling nut?
- Peter
Old 10-07-2017, 08:06 PM
Platinum Member
dad911's Avatar
If that doesn't work, wheel spacer?
Old 10-07-2017, 09:01 PM
I thought of that dilemma, too.
The goal is to extend the bolts to add some kind of carriage system on which to attach a lightweight portable grill for transport. I'm thinking I could mount the spare, then attach the coupling nuts, then attach the extension bolts, then the grill somehow.
Old 10-08-2017, 05:42 AM
Old 10-08-2017, 05:51 AM
I think I can run some ratchet straps between Serenity (the camper) and the fuel cell (the spare) and around the outside of the ion propulsion engine (the obsolete George Foremen grill) which will enable me to support the weight of the IPE on the hitch platform somehow.
After I wire up some extremely low output LED'S via the rear light circuit on Serenity into the inside of the IPE I will be able to go into hyperdrive with a twist of the wrist in the bridge.
Boo Boo thinks it just might work:
Old 10-08-2017, 02:45 PM
You do not have permissi
john70t's Avatar
Originally Posted by Crowbob View Post
The goal is to extend the bolts to add some kind of carriage system on which to attach....
Hey.
Extend them long bolts through fiberglass all you want to man.
Extend them 30 feet iffn you want.
Aw shucks.
Extend them a hundid fify feet.
But if you don't want them to unexpectedly break and possibly cause injury out in the middle of nowhere:
Tie the load to to the frame and to the big heavy steel.
Old 10-08-2017, 04:06 PM
Platinum Member
dad911's Avatar
Ah, galvanized eye nuts.....
https://www.e-rigging.com/half-inch-eye-nut?gclid=EAIaIQobChMIn8zo4pTi1gIVhoBpCh16rgDGEAQY AiABEgLYifD_BwE
Strap grill to eyes....
Old 10-08-2017, 04:21 PM
Even though those particular eye nuts only hold 3600# (green ink implied), it's a great solution if I use 3; one on each bolt.
I am concerned that the extra weight of the grill might be a negative because I'm not really sure how those bolts are supported inside the shell of the vehicle. I think I read that there's a plywood backing plate fiberglassed in there.
What a buncha good ideas!
Old 10-08-2017, 04:43 PM
Platinum Member
dad911's Avatar
I am concerned that the extra weight of the grill .......
25g One-piece Titanium Alloy Outdoor Camping Stove Gas Stove
https://www.amazon.com/dp/B014F5EXDU/ref=asc_df_B014F5EXDU5206649/?tag=hyprod-20&creative=395033&creativeASIN=B014F5EXDU&linkCode=df0&hvadid=198081946947&hvpos=1o4&hvnetw=g&hvrand=8710279018083031269&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9004009&hvtargid=pla-348528893016
Old 10-08-2017, 05:13 PM
Too big, dad.
Old 10-08-2017, 05:19 PM
wdfifteen's Avatar
That is awesome and totally doable. Based on your concept, I'll plan do to something similar to my 1947 Dodge truck, assuming IPE Hyperdrive works on 6 volt positive ground. See you in the 4th dimension.
Old 10-08-2017, 05:39 PM
Glad to know somebody gets it, wd.
The IPE is totally unrecognizable as a portable gas grill and vice versa.
It's so odd-looking I just know somebody's gonna ask what it is. It was a gift because nobody could figure out twice in a row how to deploy the thing, including me. It worked like a charm last week on a pound of bacon and filled the woods with that wonderful, magical aroma. So much so that it attracted a really interesting guy bicycling his way back home to Alaska (from Maine) to my camp.
Old 10-08-2017, 06:07 PM
