Formerly bb80sc
Vipergrün's Avatar
Blown out spark plug- Did I dodge a bullet?
My son noticed what had sounded like a small exhaust leak on his 06 Mustang V6. Last night that turned into a very loud noise. I crawled under the car this morning and see a spark plug hanging by the plug wire. There was very slight gnarl on the threads on the end of the plug. Went and bought new plugs, threaded right in and tightened it up. All of the other 5 plugs were loose, replaced them all. Car has never run better. I was fearing head work to re-thread the hole.
Is it normal for plugs to back out, blow out, and not screw up the threads? Weird, feel like we dodged a major bullet.
Whew...for now, until the next thing happens :--)
-B
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 10-14-2017, 01:20 PM
DanielDudley's Avatar
I have seen it happen. I have also seen a plug well get filled with oil, with oil seeping past the loose plug, causing the car to smoke severely at startup after not running for a few days.
Old 10-14-2017, 03:16 PM
John Rogers's Avatar
If the head threads strip out it is an easy fix if you are mechanically inclined. If not a good mechanic can do the insert in an hour or two. If your case did you torque the plugs since most new cars have some sort of thing like tighten hand tight then 1/2 turn or such.
Old 10-14-2017, 03:20 PM
I blew one out in my 78 Westy, threads and all.
As mentioned I did a Time-Sert.
Old 10-14-2017, 03:37 PM
Blew one put of my bug many years ago. My dad put in a time sert.
1982 911 Targa, 3.0L ROW with Webers
Old 10-14-2017, 04:18 PM
Senior Member
Superman's Avatar
Lots of people over-torque spark plugs, which damages the (usually) aluminum threads in the head. Tears them. Then the plug blows out.
If the spark plug as a crush washer on it, then proper torque is generally achieved when you can feel that the crush washer has finished crushing. No more. 20 lb/ft.
Mocha 1978 911SC. "Coco"
Old 10-14-2017, 04:27 PM
carreradpt's Avatar
I had a plug blow in mine (pcar). Threads were done. Time cert and a top end. Good as new.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 10-14-2017, 05:24 PM
Super common to blow out plugs in ford 5.4 engines threads and all. Lots of nice kits to repair them nowadays.
Old 10-14-2017, 07:49 PM
Formerly bb80sc
Vipergrün's Avatar
Thanks for the replies. Really odd that I could screw the new plug all the way in. Didn't feel any binding as it went in. Seems like a fairly common issue in some of these era mustangs.
Cheers
-Brad
2015 Cayman GTS
Old 10-14-2017, 08:33 PM
Almost Banned Once
sc_rufctr's Avatar
"All of the other 5 plugs were loose,"... Did some hack mechanic forget to torque up the spark plugs?
- Peter
Old 10-14-2017, 10:08 PM
pwd72s's Avatar
Since it's often difficult to impossible to get a torque wrench on a plug wrench, a good P-car mechanic gave me a tip for aluminum heads. With a new plug, tighten finger tight, then 1/2 turn to crush the washer. If installing an original plug, 1/4 turn. That puts you in the proper torque range. I don't see why this wouldn't work with iron engines as well.
(edit) A s197 Mustang forum you or your son might wish to sign up for. Very tech & hop up oriented group. There is a special section for the 2005 and up 4.0 V-6 Mustang.
http://s197forum.com/forum/index.php?
Old 10-15-2017, 12:19 AM
Still Doin Time
asphaltgambler's Avatar
^^^yes - they did^^^
Old 10-15-2017, 10:09 AM
You do not have permissi
john70t's Avatar
It could be just simple engineering:
Engine cases are made out of huge blocks of soft magnesium/aluminum/other.
Those materials are lightweight and made to do their job.
But they are vulnerable to their specific applications properties and usage.
(Obviously a superlightweight highway runner which is designed to last is not to be used as a drag strip torque monster.)
The parts that seal, grip, and/or slap together repeatedly usually need a much higher strength rating than the the whole engine block case has.
Old 10-15-2017, 04:39 PM
Laneco's Avatar
One basically falls out and the other 5 (so six total) are loose? These weren't put in right. Finger threaded and that's it. Nothing peculiar other than crappy workmanship.
angela
Hello
Old 10-16-2017, 09:14 AM
Use some Red Locktite to keep it from happening again
Old 10-16-2017, 12:47 PM
Formerly bb80sc
Vipergrün's Avatar
JB weld works better. LOL
I have a feeling the PO did the plugs before.....and did a piss-poor job.
Cheers
-Brad
2015 Cayman GTS
Old 10-16-2017, 12:55 PM
Did you get the memo?
onewhippedpuppy's Avatar
S197 Mustang Forum - S197Forum.com
That's how I do it too. Some of the plug companies will actually put a diagram on the box, finger tight plus some amount of twist with a ratchet. Torque wrench is nice, but on most modern cars you are damn lucky to even get the stupid things in/out.
‘07 Mazda RX8-8
Old 10-16-2017, 01:06 PM
