Driver
Cool Roof
I live in sunny SoCal, where it was 100+ degrees today. Going to re-roof the house, and have been introduced to cool roof shingles by the builder (currently we have asphalt shingles). In this time of global warming, this sounds like a good idea.
In short, are these worthwhile? Do they work/make a measurable difference? Does the thermal reflectivity property last, or does it wear off over time? Almost everything I've read has been written by someone trying to sell the stuff. We'll probably be in this house for the next 10 years, I'd guess.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa Last edited by Noah930; 10-23-2017 at 09:43 PM.. |
Banned
yes the roof heat can and will drive up the el bill
we painted our roof white [it was gray] with special roof paint and dropped the bill about 20% in the summer problem is trees/leaves and their effects that darken over time requires a pressure wash and repaint every few years no idea about fancy shingles but 3M or BASF should be ok quality currently pricing metal roofing for hurricanes it will be white |
Zink Racer
Solar options? I see that Tesla has started selling their roof. I assume it is very expensive. Wonder how it will actually pen out over time.
Jerry 1983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4, 1999 323ti |
Unregistered
If your roof temperature makes any difference at all, you do not have adequate attic ventilation or insulation.
Put your money where it matters. Not backaswards. |
Bandwidth AbUser
^^^ it does make sense to ventilate your attic as a first step. It's cheaper and it might make enough of a difference that you won't see the need to do anything else.
Jim R. |
i have a white roof...the difference is amazing.
i think a white roof on any type of attic would help. venting the attic is much cheaper, but if you need a new roof, take the two prong attack.
poof! gone |
Roof ventilation will help a lot. It keeps moisture from building up and lets the heat out.
Good insulation is just as important. We have a conventional brick facade house and asphalt shingles and we went to the ridge vents. They look like part of the normal roof, but they let a lot of air out. We also have vents in the soffits. We went with impact resistant shingles since a hail storm wiped out out old roof. It is astonishing how much a new roof can cost. It was nearly as much as I paid for my 911. The old roof was 25 years old so it had already lasted longer than many in the area.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Is this the product you are talking about?
Timberline® Cool Series® Energy-Saving Shingles https://www.gaf.com/Roofing/Residential/Products/Shingles/Timberline/Cool_Series/Features Quote:
![]() Many ways to lower solar heat transference rate to attic or ceiling spaces. Trick is doing it cheaply enough to recover the investment. This looks like a simple fix compared to others I could tell you about. Quote:
https://www.gaf.com/Roofing/Residential/Products ![]() Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 10-24-2017 at 08:14 AM.. |
As I've described before, I have a semi flat roof of flash down, bituminous (black) membrane. My scenario doesn't necessarily apply to your application but illustrates the difference in surface temps. After about two years, I applied a glacial white elastomeric coating. It wasn't as simple as just painting it on. It needed two coats of asphalt emulsion followed by two coats of the elastomeric coating. I used an infrared, hand held thermometer to measure the temperature before I applied it & afterwards. At ten to twelve AM, the temperature on a clear, sunny day was around 170 degrees. After the coating, it was between 100 & 110 degrees. So applying a coating like that reduced the surface temperature significantly. I also have good venting and ceiling insulation. Here the ratio of ventilation to floor space is code.
Marv Evans '69 911E |
Tesla do not have a manufacturing facility yet. These are a ways off....
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Driver
I was just wondering if what I've read is all marketing hype, or if it really makes a difference in this hot, dry climate.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
The Stick
1.) The roof is not on a house to thermally insulate the house.
2.) The roof is there to keep the precipitation out of the house. 3.) The insulation on the houses ceiling in the attic is what insulates the living area of the house. 4.) The roof is ventilated mainly to let moisture in the attic dry out, but also lets excess heat out. 5.) Insulated roofing tiles only keeps the sun from heating the attic more than ambient temps outside (see #4). 6.) Heating an attic in the winter when snow is on the roof is bad. It causes the melt runoff covered by the snow to pool at the soffits, leak, and rot them. Hence the ventilation.
Richard aka "The Stick" 06 Cayenne S Titanium Edition |
Super Moderator
No pressure, but the attention to proper ventilation and flashings are going to help any system. Pretty smart of GAF to bundle package their products like that warranty wise, because the devil in is the details. A decade or two ago some of the trade magazines were advocating a air cavity roof, meaning you have a regular roof minus the shingles, then lay vertical furring strips down, a layer of OSB on that, roof felt and shingle over the top. What you end up with is air layer that is vented top and bottom getting moisture from the due point out of the inside of the house and inside of the material themselves. In addition both sides of the shingles are now evenly cold or warm, making them last much longer. SIP construction with Roxul on interior service cavity wall | GreenBuildingAdvisor.com ![]() Also see this large image: http://bkaviking.blob.core.windows.net/media/1172/roof-to-wall-venting-detail-ct10.png ![]() You can imagine that this air cavity would do a good job of preventing heat from the shingles transferring through to the rest of the house. From what I can tell looking on-line they now add reflective membranes into the mix to radiate energy (infrared) back out. And they seem to be more for cathedral ceilings where they can do the most good. Lots of ways to spend money, lots of ways to overkill. I say using a shingle with reflective properties is a no-brainer to start with. Don't skimp on ridge vents and valley flashings. The flat roof can be problematic. Unless you are using only rigid insulation on the top, the batt insulation or blow-in insulation in between the ceiling joists really could benefit from being ventilated as well. This gets skipped sometimes and moisture can build up in the insulation causing sagging, dripping, mold, and in cold climates freezing. Below is the type of vent/flashing made to address such conditions. Flat Roof: Flat Roof Upstand Ventilation ![]() https://www.diynot.com/diy/media/untitled.15937/ Alternate-1: Smart Flat Roofs: The Craft of Parapet Detailing | BUILD Blog ![]() Alternate-2: http://eureka4you.com/home/VentFlat.htm Quote:
If you have existing flat roof drainage issues, perhaps look into adding tapered rigid insulation to increase the pitch. Yes, they make white and reflective flat roof membrane roofing that helps lower cooling costs, look into it. Sounds like most of the people posting used the "come back and fix" type treatments and materials on flat roofs. There are retrofit and new or re-roofing materials as well to meet your criteria.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 10-25-2017 at 04:10 AM.. |
Banned
Three years ago we replaced the asphalt shingle roof on our house with Brava Tile shingles and at the same time re-decked with solar barrier decking. Cut our summer electric bill in half. Winter bill cut by 1/3. Ours was the second house in Dallas to use Brava Tile. People visit our house to see the roof. Two weeks ago a couple from Cedar Rapids Iowa flew to Dallas to see our roof.
Brava Tile looks like ceramic Spanish tile but weighs less than standard asphalt shingles so you don't have to strengthen a roof to use them. Brava Tile also has roof tiles that look like slate and ones that look like cedar shakes. https://www.bravarooftile.com/ (Our house was designed/built by a couple from Los Angeles and it doesn't look like a typical Dallas house.) ![]() Winter shot to show insulating properties of Brava Tile roof
Banned
took about 5 buckets to do 1200 sf as it is very thick we did the painting so under 400 total cost bills were about 350 before dropped to high 2xx peak summer a/c is a mid 90's and low er rated maybe 10 problem is the huge royal poinciana tree that flowers and attracts ants that bring aphids that make honeydew that creates black mold on the roof requiring pressure washing after a few years the mold stains the paint to a gray and we repaint but as the thick paint base is still ok just stained repainting uses far less thinner normal paint 2 buckets to do the whole roof and the paint is far cheaper if you do not have a tree+ant+aphids=staining it should last longer and require less pressure-washing or repainting |
Banned
I would NOT use OSB on any house ever anywhere
not even a dog house esp on a roof as once a leak starts that crap crumbles and hurricanes love to turn OSB to debris |
I just call out "roof sheathing" and let the builder settle with the owner as I have near zero influence on such matters. Where this matters most is extreem cold or hot and humid climates, the local guys know what to use. I once helped a buddy repair a bay window where there was not continuous house wrap. The OSB wall sheathing fell apart like "nota" describes. I'm not a fan to say the least, very unforgiving of less than perfect work. From what I understand Europeans laugh at our temporary stick built houses, if you want to get serious, concrete is the way to go. That's what the rest of the world uses.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 10-25-2017 at 02:05 PM.. |
You live in Cal, tile or slate, asphalt is for roads
Driver
Do you recall the name/manufacturer of the product? Was it a Home Depot purchase, online, or from a specialty supplier?
