dan79brooklyn's Avatar
Two car questions I’ve always wondered about...
1. In an automatic transmission car. When stopped, does it harm the transmission to put the car in neutral?
2. When using fuel system cleaner (Techron/STP) is it better to run it through the engine before you do an oil change or after?
I’ve always wondered about the two questions above. Curious what the Pelican brain trust thinks...Thanks.
Old 10-26-2017, 05:11 PM
Cars & Coffee Killer
legion's Avatar
1) Not really. I had to do that in a car with idle issue years ago as it takes load off the engine (doesn't have to turn the torque converter).
2) I don't think it matters.
5 liters of VVT fury now
-Chris
Old 10-26-2017, 05:16 PM
Used to be Singpilot...
Location: Sioux Falls, SD is what the reg says on the bus.
1) Some transmissions do not cool the trans fluid in neutral. If the brake rotors are overheated, putting it in neutral and releasing the majority of the applied brake pressure might prevent warping. Idle issues aside, no reason to put it in neutral.
2) Old school said that Techron should be prior to oil change. Idea was that soluable dirt and gunk would migrate to the oil. I guess past rings, valve seals, PCV...
Maybe our oil doc, Holloway could chime in.
Old 10-26-2017, 05:28 PM
T77911S's Avatar
I thought it would get burned up and/or pushed out the exhaust.
don't know much about tranny's but I thought if the oil pump is working oil would still go thru the oil cooler. not sure why it would not.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-27-2017, 04:06 AM
(the shotguns)
berettafan's Avatar
re question 2 I'd go with 'right before an oil change'.
iirc one of the high end fuel treatments (44k or something like that) might even suggest an oil change after.
Old 10-27-2017, 04:23 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
What’s an “automatic transmission”?
Old 10-27-2017, 05:28 AM
Arizona_928's Avatar
Shouldn't harm the transmission at all. Usually the pump is on the main input shaft. As long as the engine is spinning, that pump is pumping.
dolor et pavor
Copyright
Old 10-27-2017, 05:38 AM
Still Doin Time
asphaltgambler's Avatar
1) no - 2) doesn't matter
1) as long as the engine is running, the trans fluid is being circulated, pressurized and cooled.
2) most fuel cleaners/ additives are largely alcohol. A few exceptions are GM Top Engine Clean & BG 44 which are designed with the professional technician in mind.
Old 10-27-2017, 07:18 AM
vash's Avatar
1. no...if so, i figured idling the car in PARK would suck as well.
2. i know folks that ONLY run chevron fuel in their cars. it has techron in it full time..that would sully the oil change regiment..no? or is it a matter of dosage?
gah..i need to get off my ass and do some car maint before my long long loooong drive. next weekend.
poof! gone
Old 10-27-2017, 07:28 AM
Edministrator
Steve Carlton's Avatar
Does Chevron premium have more Techron than regular? I heard it used to- don't know if that's true anymore.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 10-27-2017, 08:14 AM
Team California
speeder's Avatar
I think that you might be overestimating what Techron, (or other fuel additives), can do. They might clean you injectors and fuel system somewhat, (-might-), but whatever they are cleaning would surely get burned along w the fuel it is diluted in, I would think.
Fuel and oil additives definitely can work, I've had great luck w ATF or Seafoam in crankcases freeing-up sticky hydraulic lifters and rings, for example.
Great to see you here, BTW!
Denis
Old 10-27-2017, 09:11 AM
Edministrator
Any opinion on ATF or Seafoam vs SWEPCO 502 Premium Engine Oil Improver
O - $1
O - $2
O - $3
Old 10-27-2017, 10:33 AM
Team California
speeder's Avatar
Completely different things. That Swepco product is an additive package that you add to your exiting oil and ATF or Seafoam is more of an enema, just a super detergent to run through and then change your oil soon after.
Denis
Old 10-27-2017, 11:10 AM
