-   -   How do I identify a resistor ? (http://forums.pelicanparts.com/off-topic-discussions/980313-how-do-i-identify-resistor.html)
sc_rufctr 12-10-2017 09:16 PM
Originally Posted by DanielDudley (Post 9843890)
And what is the idiot's guide ?
Do you mean the "Nerd Perks" card?
Have you ever noticed the colored stripes on a resistor? On the left of the card it shows the resistor color codes.
This may be more helpful.
http://forums.pelicanparts.com/uploa...1512969354.jpg
dad911 12-10-2017 10:18 PM
No card, still remember:
Big Boys Race Our Young Girls But Violet Generally Wins.... and a few other less PC versions.
DanielDudley 12-11-2017 03:09 AM
I have seen the stripes. It did not help for me that the diode was orange with black ''stripes''. It has been 45 years since I messed with any of that stuff. I assembled a Heathkit stereo, and that was about it. This is a big help for me, and I appreciate it.
Thanks, Guys.
T77911S 12-11-2017 05:09 AM
bob brown rapes our young girls but violet gives willingly .
red-beard 12-11-2017 05:19 AM
Bad boys rape our young girls, but violet goes willingly
The only thing you have to remember is "black brown" at the start.
red-beard 12-11-2017 05:28 AM
The old GE MK IV control systems had a 4-20mA input section and the fuse was rated too high (0.5 amps). If you applied 24VDC to the circuit, the resister would blow, saving the fuse. I kept lots of the the correct resistors around. I would go to an electronics store, go to the precision bin and then use a meter to check and find the ones that were PRECISELY 250 ohms. These were 1/4 Watt resistors.
I'd assign an electrical tech and a few minutes later, everything was working.
MBAtarga 12-11-2017 09:39 AM
Alligator clips can be used as a heat sink as well. As close to the soldering location as possible decreases the amount of heat hitting the component.
fintstone 12-11-2017 12:30 PM
On an automotive gas gauge, a 12v 1N4742A 1W zener diode seems more likely. What did the gauge come off of?
https://www.ebay.com/itm/New-10-Pcs-x-1N4742A-1N4742-ZENER-DIODE-1W-12V-SALE/151138408274?_trkparms=aid%3D222007%26algo%3DSIM.M BE%26ao%3D1%26asc%3D20160908110712%26meid%3D353d02 363be44fca8e5eee5a6fb0f8eb%26pid%3D100677%26rk%3D3 %26rkt%3D30%26sd%3D221743500814&_trksid=p2385738.c 100677.m4598
Robert Coats 12-11-2017 01:09 PM
I was taught a slightly more bawdy version:
Bad Boys Rob Our Young Girls But Violet Gives Willingly. :)
DanielDudley 12-11-2017 01:59 PM
That looks a lot more like it Fint, but the numbers clearly read 40 04.
It's a Veglia Borletti gauge out of an 81 fuel injected Fiat Spider 2000.
Edit; Ordered a few anyway.
dad911 03-29-2018 09:35 AM
Just curious, did the diode swap work out?
Don Ro 03-29-2018 09:44 AM
And then the tolerance rates:
Gold
Silver
No color
"Get Some?" "No."
Jingles are great for bad a memory, eh?
red-beard 03-29-2018 10:49 AM
I was only taught the less PC version...Willingly
scottmandue 03-29-2018 11:14 AM
Forceps work well too if you have some handy.
