How do I identify a resistor ?
Fried a resistor in a gas gauge. It is orange with the black end, and seems to hae an 04 on it and an I T something under that. It's fried. I would take this to Radio Shack to match up, but those days are gone.
Any help would be appreciated. It seems a shame to waste an otherwise good gauge. |
pic pls.
It would seem this is more likely a diode than a resistor. Pic would help as others have requested.
That’s a diode.
Easy fix. |
1K 40 04 IT? It rolls around like that. |
Yup, I lose.
physically broken? 1N4004 is popular diode. (is it N instead of k?) |
2.29 on Ebay. Thanks guys.
I just checked my junk drawer. Sorry don't have any.
10 for $5 on amazon prime. |
Just took a look. Found one in my spare parts bin - used, but it checks out okay with my meter. Send me a PM with your address and it can be on its way tmr if you want it.
https://uploads.tapatalk-cdn.com/201...795cfa7fc7.jpg Sent from my iPhone using Tapatalk Pro |
Thanks Mark, I already ordered a few. Now I just have to be patient.
Do I need to use a heat sink on the wires while soldering ? |
When I usually have a burnt up resistor it burns off the stripes and I have to find it on the schematics to see what the heck it was.
That does look more like a diode than a resistor though. |
Solder carefully, they don't stand up well to excess heat. Use the bare minimum of time with the iron on the component, and use a heat sink.
Needle nose pliers with a rubber band to keep it shut will soak the heat. Between the solder joint and the diode.
Solder pencil, not a gun. ;) |
| All times are GMT -8. The time now is 07:32 AM. |
