Driver
Noah930's Avatar
Drilling through tile
We are in the final stages of a home renovation/addition project in the Noah household. We have installed subway tile (3"x6") in one bathroom, around the tub/shower. I hate those expandable shower curtain rods that always seem to slip and fall. Therefore I want to install a permanent shower curtain rod, where the ends are held in place, screwed into the walls. My general contractor refuses to drill through the tile, as he is afraid the tile will crack. I understand his concern, as drilling through tile isn't the same as drilling into sheetrock or wood studs, but is there some sort of unwritten rule that you should never ever drill holes through subway tile?
Again, the tiles are oriented in traditional staggered configuration horizontally and measure 3"x6", so they're not big. The curtain rod's mounting plate is about 2" in diameter, with horizontally-oriented mounting holes (holes are to be side-by-side, not one on top of the other), so I should be able to put both holes into one piece of tile, decently away from any tile edges.
1990 Black 964 C2 Targa
Old 01-17-2018, 10:30 AM
JavaBrewer's Avatar
With a masonry drill bit I wouldn't have any concerns drilling into ceramic tile. The hardest part is getting the hole started right where you want it. A steady hand and some patience wins out.
Old 01-17-2018, 10:36 AM
I mounted the shower rods (those kind that bow out at the top) in our showers without any problem. If you have porcelain tile, I think you need to get a dedicated bit for porcelain.
Marv Evans
'69 911E
Old 01-17-2018, 10:37 AM
Make Bruins Great Again
Por_sha911's Avatar
Wouldn't the proper adhesive do the same thing with no risk of cracking or water leaking?
Joe
Old 01-17-2018, 10:40 AM
As long as you have stud backing behind the tile to drive screws into no biggy. I'd use a carbide scribe to cut through the top layer of the tile and drill with about anything. Do no use a hammer drill function btw. The tile would probably eventually crack no matter if you drill through it or not. Up at the rod it's out of the water zone anyway so who cares. If contractor is that worried just have half a box saved or so for a later date if it doesn't work out
Old 01-17-2018, 10:47 AM
Driver
Noah930's Avatar
Interesting question. Anyone know of an epoxy I could use in this situation?
Old 01-17-2018, 10:52 AM
Control Group
Tobra's Avatar
Paging Trekkor
Old 01-17-2018, 10:54 AM
Maybe I don't know what the hell I'm doing, but in my past, I've never had any success drilling through porclean tiles no matter what type of bits I used, and I tried several....years ago. Floor tiles though....I don't even try anymore....I just plan tile layouts, etc. ahead of time and use my tile wetsaw to make appropriate cuts....YMMV. I wouldn't even try....use an adhesive imo....
Trekkor will know....
Old 01-17-2018, 11:02 AM
craigster59's Avatar
I've had success with Bosch bits.
https://www.amazon.com/Bosch-GT2000-Glass-Tile-4-Piece/dp/B001GNC8RI/ref=sr_1_3?ie=UTF8&qid=1516216125&sr=8-3&keywords=bosch+tile+bit
Old 01-17-2018, 11:09 AM
^^^ Use these bits and go SLOW. Let the bit drill the hole and use very little pressure on the drill.
Old 01-17-2018, 11:41 AM
Automotive body molding tape? I kept the bodywork on a lot of Pontiacs attached for lots of years.
Brent
Old 01-17-2018, 11:42 AM
why wouldn't you drill into the grout between the tiles? any cracking would be covered by the trim piece.
1980 911SC Targa 3.6L
Old 01-17-2018, 11:58 AM
Unhappy
What's the backup plan if the tiles crack, etc.?
If Trekkor can recommend an adhesive, that's the route I would pursue if it were me...YMMV.
That's if it's just holding a shower rod & curtain though....if ya wanna do pullups or use it for kinky shower sex then mebbe not
Old 01-17-2018, 12:15 PM
Unregistered
sammyg2's Avatar
I recently installed shower doors and drilled through tile using these style bits. They weren't bosch but worked perfectly. No cracked tiles, no drama.
Got em at home despot.
Old 01-17-2018, 12:36 PM
MBAtarga's Avatar
From the big box store:
https://www.homedepot.com/p/DEWALT-1-4-in-Diamond-Drill-Bit-DW5572/202548301
I've used this style diamond tipped bit but in Hitachi brand. Works great! Made for porcelain and other tile.
Mark
'83 SC Targa - since 5/5/2001
Old 01-17-2018, 12:46 PM
vash's Avatar
put a piece of blue tape down..then mark the hole on the tape. drill thru. the tape gives you just enough traction to allow the drill to go into the right spot.
poof! gone
Old 01-17-2018, 12:54 PM
JavaBrewer's Avatar
put a piece of blue tape down..then mark the hole on the tape. Drill thru. The tape gives you just enough traction to allow the drill to go into the right spot.
+1
Old 01-17-2018, 01:15 PM
There are bits for drilling through glass tiles. They don't last long but you can extend their life by spraying water as you slowly drill.
Old 01-17-2018, 02:28 PM
Platinum Member
dad911's Avatar
If you are doing a straight rod, just use the curtain rods that expand. They old up fine.
If you really want to drill it, I've used the bosche bits also.
Old 01-17-2018, 02:46 PM
A930Rocket's Avatar
This is what I've always done.
Same for exterior brick.
Old 01-17-2018, 02:52 PM
