Control Group
Tobra's Avatar
Aluminum anti-seize?
Need to do spark plugs this weekend, and picked up some anti-seize. Did not really read it until I got home, and it says aluminum. I always thought this was copper, not aluminum. Is aluminum anti-seize equivalent, or do I need to go back and swap it for the copper stuff?
Old 02-08-2018, 06:21 PM
canna change law physics
red-beard's Avatar
https://www.autozone.com/miscellaneous-cleaners-and-degreasers/lube/permatex-1-oz-28-35-g-anti-seize-lubricant/526814_0_0
A highly refined blend of aluminum, copper and graphite lubricants. Use during assembly to prevent galling, corrosion and seizing due to weathering or chemicals.
Anti-Seize assures easier disassembly.
Temperature range: -60°F to 1600°F (-51°C to 871°C).
Salt, corrosion and moisture resistant: ideal for marine use.
Non-aerosol version meets Mil Spec #907E. aerosol – level 3*
James
Red-beard for President, 2020
Old 02-08-2018, 06:25 PM
John Rogers's Avatar
wow James sounds like it could even take the place of K-Y if someone ran out?!
Old 02-08-2018, 08:17 PM
drkshdw's Avatar
If you've never used it before handle it carefully. With gloves. And a tyvek suit. You get one tiny speck of it somewhere that it shouldn't be and it will show up in your hair two weeks from Wednesday.
Old 02-08-2018, 08:58 PM
And it will be a bear to get off your skin/hair/her lady parts
Old 02-08-2018, 09:53 PM
Did you get the memo?
onewhippedpuppy's Avatar
Also make sure it’s even needed. Most modern engines don’t require anti-seize, and some manufacturers recommend against it.
‘07 Mazda RX8
Old 02-09-2018, 04:36 AM
fastfredracing's Avatar
this
No left turn un stoned
Old 02-09-2018, 04:48 AM
Recreational Mechanic
Nickshu's Avatar
Most current spark plugs have an anti-sieze coating on the threads already. Usually indicated on the package insert. Last two sets I have installed (one NGK and one Bosch) indicate this on the package insert.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 02-09-2018, 05:10 AM
I just installed a set of NGK plugs in the wife's Deville and they were pre lubed. It was hard to see, like a dry coating.
Old 02-09-2018, 06:03 AM
red-beard's Avatar
I don't think I'd want a silver dongle...
James
Old 02-11-2018, 06:48 PM
