Hi
Targa Me's Avatar
House Windows Upgrade
Hello Everyone,
I'm considering upgrading the windows in my house.
Is this something left up to the professional installer or is this something I can tackle on my own (with helper)?
I just got a quote on windows today, we're looking at 10 to 11k. Ouch !
What's your opinion.
Thanks.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 03-23-2018, 01:12 PM
Brew Master
cabmandone's Avatar
Not hard to do. Depends mostly on what you're replacing.
Old 03-23-2018, 01:16 PM
I've seen some videos. It looks pretty easy. And I suspect once you've seen one pulled out, you could probably do as good or better a job almost as fast. That said, I've never done it myself.
I think the key is having good measurements and getting the right size replacement windows.
Old 03-23-2018, 01:17 PM
No experience with replacing/upgrading windows, but I'm sure you are looking at low-E, dual pane. When I built my house, I also learned new construction in my area required tempered glass. Don't know your exact area, but that might be a requirement.
Marv Evans
'69 911E
Old 03-23-2018, 01:19 PM
vash's Avatar
hell, even i did it!!
i did all my old house double pane windows. i chose a retrofit system from Marvin..they call it the tilt-pac. seriously, the hardest part was doing the measuring before the order. ask questions!! i almost blew it on a few windows..that lower sill angle messed me up.
i did also replace to double panes with a casement(that what they call it?)..it was even easier!!
if you have 1970 era alum windows now...i dunno. not in my wheelhouse.
poof! gone
Old 03-23-2018, 01:21 PM
biosurfer1's Avatar
I will have to replace several windows in my house soon. Biggest pain is I have stucco on the outside of the house which complicates things.
I'd love to find a retrofit solution.
1992 968 Polar Silver
2010 Toyota Highlander SE
2006 Lexus LS430 ML
Old 03-23-2018, 01:26 PM
I just replaced 7 windows in my home.
Mine are double hung windows in wood frames. There are several youtube videos that show the process. Basically, remove interior trim, remove lower window, remove center stop, remove upper window.
Seal surfaces with caulking, insert new window assembly, center, plumg, and level than screw into place, replace interior trim.
When measuring windows, measure opening, subtrace 1/4" from legnth & width.
Old 03-23-2018, 01:30 PM
FPB111's Avatar
It also depends on the type of siding on your house.
I did our cedar shingled house using Anderson casement windows (20).
I pulled the inside trim off and measured the rough openings then compared to the Anderson window catalog. That also allowed me to order the new windows one or two at a time so that I could space the installations on my schedule.
Most of the windows were in stock at our local lumber yard and or Window World stores.
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 03-23-2018, 01:36 PM
I’ve done several now and they are pretty simple as long as you have a standard size, otherwise you might have to reframe or make wider trim.
I also helped a friend put in the type where you just pull out the double hung guts leaving the frame in place and that took us less than an hour- did it in the middle of a MN winter.
For what the window companies charge, they must make huge profits on the job.
Rutager West
Old 03-23-2018, 03:21 PM
I remember the day we had ours replaced. Hot, windy (Santa Ana's blowing) day in Aug. I know we didn't pay that much for them since we don't have that kind of money. We got Milgard Low E, pretty simple windows and a new slider for the family room. They insisted on tearing out the old slider framing and putting in new, which now that its been done I'm OK with and glad they did. NO leaks from it and the step over isn't as bad as it would be if they'd left it in. Once I saw how easy it was to put the windows in, I was kind of wishing I'd done it myself, until a window almost got smashed from the wind. It would have been on their dime not mine to replace it. Our windows are a joy to open/close now as the old aluminum ones were really in pretty bad shape. The noise abatement is fantastic with the double pane too. The Low E has it's drawbacks as we quickly learned how much heat we gained during the winter from the sunlight coming in. We've since had the HVAC system upgraded from wall furnaces to forced heat and a/c. The whole replacement job took them a day, including the re-stuccoing of the slider door frame.
Scott
'78 SC mit Sportomatic - Sold
Old 03-23-2018, 03:56 PM
LWJ LWJ is online now
If you live somewhere with rain, please reconsider. I am a very DIY person and I would never do this in Oregon.
Probably would DIY in Southern California.
Old 03-23-2018, 04:02 PM
What kind of window and how are you installing them? If you are near LA, I can turn you on to a couple of people I use and trust.
Old 03-23-2018, 05:36 PM
Scott R's Avatar
We had 48 windows to be done in November by Pella on a three story home. There was no way I would have been able to do it myself. It took the "pros" three install appointments to complete it working 12 hours each time.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-23-2018, 07:26 PM
Originally Posted by Targa Me View Post
Hello Everyone,
Thanks.
I agree. Just dont fall off the ladder like I did. Week in the hospital. Another week in rehab. Five months, no work. Another 2 months before I could walk good. Still have metal rods and 13 screws in my leg. And still had to pay the installer to finish the job.
Old 03-23-2018, 08:02 PM
