vash's Avatar
Engine oil capacity.
Back in the day; was it typically 5qt?
Now it is all over the place. I check the owners manual almost every single time.
My tacoma is 4.8 qts, but if I let it really drip..5 qt is perfect on the dipstick.
Just did my wife’s Subaru. 4.2 qts. It took about 4.4ish to look great on the dipstick.
I always have partial bottles everywhere.
poof! gone
Old 04-22-2018, 06:29 PM
Make Bruins Great Again
Por_sha911's Avatar
Oil filters used to be a lot larger and that was more oil too.
Why not use up the left over clean oil from the last fill? I just get it close (but under what I expect) and then top off after startup.
Joe
Old 04-22-2018, 06:34 PM
Cars & Coffee Killer
legion's Avatar
The Mustang takes 8 quarts. Feels like I'm changing the oil in a Porsche...
5 liters of VVT fury now
-Chris
Old 04-22-2018, 06:35 PM
pete3799's Avatar
Wife's Passat takes 6.3 qt. Just changed it today. I hate the cartridge filter on it. What a PIA.
Pete
79 911SC RoW
Old 04-22-2018, 06:38 PM
vash's Avatar
At least they don’t use fractions
poof! gone
Old 04-22-2018, 06:41 PM
unindicted co-conspirator
looneybin's Avatar
I mix the leftover oil with a little bit of ATF
It makes great gun oil
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 04-22-2018, 06:48 PM
fastfredracing's Avatar
Not only is the capacity all over the place, so is the viscosity, and requirements It is crazy how many different fluids I have to stock, and I have to look everything up, even for simple oil changes
No left turn un stoned
Old 04-22-2018, 06:53 PM
weekend wOrrier
On my 911 it's something like 12 quarts....13...14...15....16.....17...(change oil) 12 more....13....14...15....(clean off garage floor)
Old 04-22-2018, 07:08 PM
MBAtarga's Avatar
When I take ownership of a vehicle, I take a sharpie, and write down qts capacity and the drain plug socket size at the front left fender well. Whenever I pop the hood to do the oil change service, I don't have to double-check for the info as it's right there.
Mark
'83 SC Targa - since 5/5/2001
Old 04-22-2018, 07:42 PM
drkshdw's Avatar
My 99 Camry takes 2.5 quarts. $4 for a filter at the dealer. Cheapest car ever to do an oil change on.
Old 04-22-2018, 08:09 PM
KNS KNS is offline
Oil filters have gotten down right tiny!
I miss my ‘68 Volkswagen, took pints of oil instead of quarts. I remember I could find Castrol 30Wt on sale for 79 cents a quart.
Kurt
Old 04-22-2018, 08:16 PM
D idn't E arn I t
RANDY P's Avatar
Try draining it overnight, and you'll get almost 4.75Qt on refill. I run about 500 miles, about then oil starts to burn off from a few heat cycles, add the rest.
rjp
In the movies only bad guys sleep in king size beds.
Old 04-22-2018, 08:49 PM
DanielDudley's Avatar
I used to get industrial filters to bring up capacities to an even number. They were big filters.
Now every filter I see is about the size of a big walnut. Seems like a strange direction to go with extended oil change intervals.
Old 04-23-2018, 03:03 AM
Both my 1999 F250 powerstroke, and my 2003 6.0L powerstroke take 14.5 qts every 5000 miles.
Old 04-23-2018, 03:40 AM
Almost Banned Once
sc_rufctr's Avatar
I just dump in the first 5 liter container and then add 1/2 of the next container and then bring up the level slowly.
(It's about 8 liters for a 400SE)
Once it's on the dip stick it doesn't take much to get it to the top level.
And yes if you over fill it it's worth sucking out the extra oil to bring it down to the correct level.
- Peter
Old 04-23-2018, 03:45 AM
This is what our truck and the Cobra takes. I used K&N because it has a 1" nut for size reference.
Brent
Old 04-23-2018, 12:21 PM
Control Group
Tobra's Avatar
Miata is about 4 quarts, including the filter. 914 or bug is practically nothing.
Old 04-23-2018, 12:24 PM
I'm with Bill
Jims5543's Avatar
Brilliant!!!
I am going to do that too.
I was just commenting to the wife, part of the delight with the i3 is not worrying about oil changes anymore.
I think we have put over 5K miles on it in 3 months. No need to keep track of oil changes.
1978 Mini Cooper Pickup
1991 BMW 318i M50 2.8 swap
2005 Mini Cooper S
Old 04-23-2018, 12:26 PM
