Is there a right way to shut off a torch .
Oxy acetylene , seems as if my tips are always clogging, and I am constantly cleaning them.
I used it this morning, it was working perfect, picked it up just now, and spitting and sputtering, flame only coming out of 3 of the little holes in the tip. Should I not shut it off hot, and maybe turn off the oxy, and let it cool down with a small acetylene flame for a few seconds ? I figured , if any body knows, someone here would .
No left turn un stoned |
unindicted co-conspirator
could you have some small debris in the line?
i've seen where the hoses can get dirty laying the back of a truck bed, then when attached to the tanks, the dirt/sand gets into the system maybe get a skull head snuffer, and say "the tribe has spoken" and it should be fine //sarcasm font//
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
I don't believe it is debris. It always looks like slag has clogged the little holes.
I did a quick research and found most sites recommend shutting off the oxy first when using acetylene as a fuel.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Unregistered
Shut off O2 first, then fuel.
It'll cause more soot and could dirty up your tip but at least you won't be testing your backflow preventer to see if the cylinder explodes or not. Of course that's an exaggeration but i have seen backfire pops damage torches and blow holes in hoses. Anytime I hear a loud bang in my shop, someone is going on mop detail. Last edited by sammyg2; 05-15-2018 at 10:29 AM.. |
Fleabit peanut monkey
This is interesting. Have been looking at an Oxy/Propane setup for a bit to upgrade my Bernzomatic two tiny tank set up.
This guy does just the reverse. See 3:00 in.
1981 911SC Targa |
i always shut the oxy. off first. Don't know if it really makes a difference or not.
Check your O rings and make sure everything is tight. I run 7 lbs acetylene and 30 on oxy. for cutting.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Unregistered
If you shut off the fuel first, there's a good chance the torch will backfire and the flame can travel backwards towards the regulator. The backflow preventer is supposed to ... prevent this.
The same thing can happen if you turn up the oxygen too high. Not allowed in my shop. Quote:
Also, no lubrication allowed on the fittings or o-rings that could come in contact with the O2, and never use acetylene unless the tank is vertical and has been that way for at least a half hour. Otherwise the acetone can hit the torch which on a good/bad scale is way down at the bottom, near the bad mark. And never over 25 psi on the reg. I usually don't go over 15 psi. ![]() ![]()
Shutting off the oxygen first will let you know if you have an acetylene leak.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Learn something new every day here. I guess I could have looked this up on my own, but you guys are great. I appreciate it .
I always shut down n the oxy first, so, i guess I am doing it right. Ill fine tune my reglaotors tomorrow morning
Unregistered
About a hundred years ago a co-worker was bored on the 4th of July as he didn't have his usual load of fireworks for the neighborhood block party.
So he got an idea: He got out his oxy/acetylene torch and lit it and adjusted it to a neutral flame, and snuffed it out against a 2x4. He then stuck the torch in a hefty bag and filled up the bag and tied it off. He wrapped some toilet paper around a string for a fuse and lit it and ran away. It went boom. Really really boom. It was on the side of his house and the explosion caved in the stucco wall and lifted the roof off the rafters on his house and his neighbor's house. He made bail the next day. Don't try this at home. |
Unregistered
I'm thinking it looked something like this:
Unregistered
Unregistered
You do not have permissi
Interesting. I've always used 5/15 or 7/20 but you probably work with heavy stuff.
OxyAcet is getting expensive. For heating bolts I use the welding tip on my bitty portable kit. 3/12 or something like that.
Ive been thinking about trying propane. I bought the tip a few weeks back I don't generally do much heavy cutting, usually just a muffler, or heating exhaust manifold bolts , and general light duty stuff.
Unregistered
I just spent almost $3000 on a couple of OSHA approved bottle carts with the fire wall between the bottles. |
Make Bruins Great Again
Chuck Norris style: pinch the flame out with your thumb and forefinger.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
