Whoopsies I was banned!!!
FYI Heads-Up VPNfilter malware on Routers
Folks,
I just ran across this article about VPNfilter malware being inserted onto routers, to include ones which may be in our homes. https://www.reuters.com/article/us-usa-cyber-routers/fbi-says-foreign-hackers-have-compromised-home-router-devices-idUSKCN1IQ2DY You may want to do a search for your particular home router to see what the manufacturer recommends for handling the matter. |
canna change law physics
Really good article
https://arstechnica.com/information-technology/2018/05/hackers-infect-500000-consumer-routers-all-over-the-world-with-malware/ Linksys E1200 Linksys E2500 Linksys WRVS4400N Mikrotik RouterOS for Cloud Core Routers: Versions 1016, 1036, and 1072 Netgear DGN2200 Netgear R6400 Netgear R7000 Netgear R8000 Netgear WNR1000 Netgear WNR2000 QNAP TS251 QNAP TS439 Pro Other QNAP NAS devices running QTS software TP-Link R600VPN Best thing: Do a factory reset, then update the router to the latest firmware
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Netgear is advising customers that, in addition to applying the latest firmware updates and changing default passwords, users should ensure that remote management is turned off on their router. Remote management is turned off by default and can only be turned on using the router's advanced settings. To turn it off, they should go to www.routerlogin.net in their browser and log in using their admin credentials. From there, they should click "Advanced" followed by "Remote Management". If the check box for "Turn Remote Management On" is selected, clear it and click "Apply" to save changes.
I see you
??? huh? You are not connected to your Router’s WiFi network. To access routerlogin.net, your device must be connected to your Router’s WiFi network. Check your current connection and try again.
Mine is on the list. If I do the reset what must I do to get back to regular function? This stuff is greek-ish to me.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." Last edited by flatbutt; 05-25-2018 at 07:57 PM.. |
You'll need to log in to the router and redo all settings. Make sure to disable remote management and to setup a new admin password.
1. Reboot Router
2. Login to router and write down/screen print all settings 3. Factory Reset 4. Update Firmware 5. Redo all settings using stuff from line 2
I see you
edit: OK so I go in and changed the quest password and disabled other devices from access but it wasn't called "remote access". I'll reboot once I read more.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." Last edited by flatbutt; 05-25-2018 at 08:41 PM.. |
I see you
YO! I went thru all the steps and now I can't connect to my wireless network. I had to go back to ethernet cable. WTF?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Banned
likely you need to resetup the network from step one
as you wiped the settings |
