Any of our local forum pilots build a Stratux?
Howdy,
I was just curious if any of our pilots built themselves a Stratux? ![]() ![]() ![]() ![]() ![]() ![]() Everything went as planned, right up to the power test. When ordering all of my components, I ordered up the Raspberry I was informed that they were now selling the Pi 3 B+. I didn’t think anything of it figuring it would be fine. My question to the Group is, has anyone figured out how to make the new board comparable with the FW?? Since I cannot get the Stratux to boot up, I’m thinking it’s a FW issue. ![]() Thoughts? Sent from my iPhone using Tapatalk
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 Last edited by bugstrider; 06-03-2018 at 08:41 AM.. |
The Unsettler
There are a number of possibilities, you need to eliminate some to get to the solution.
Since PI's boot from SD cards I would first verify the board is not DOA and the current card is good / OS installed correctly. Get another SD card, make sure you get an 8 GB ( or better) class 10 card. Download NOOBS and build a boot disk. Plug the PI into a TV / monitor via HDMI and see if it boots. If yes I would reload whatever OS you are using for the Stratux and try again with no peripherals hooked up. If it boots start adding stuff in.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Thanks! I'll start working on your recommendations.
I know enough about the finer Pi details to be dangerous. But I am willing to learn..... Cheers Sent from my iPad using Tapatalk
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 |
The Unsettler
When you download NOOBS there should be links for standalone 3rd party formatting utilities that will do it the right way.
You do not have permissi
Here is a good article that is a couple years old. https://www.eaa.org/en/eaa/eaa-news-and-aviation-news/bits-and-pieces-newsletter/06-14-2016-stratux-ads-b-weather-and-traffic Sent from my iPad using Tapatalk
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 Last edited by bugstrider; 06-03-2018 at 10:59 PM.. |
Well, I guess the software engineer set me straight.. obviously I did not follow the proper parts list.
![]() Sent from my iPhone using Tapatalk
