Body wrap in lieu of repainting
My '93 BMW 325is was left outdoors by the previous owner until I bought it recently. Its paint has gone bad, and all of the estimates for repainting it specify taking it all the way down to bare metal. Would a vinyl wrap job be a viable alternative? Does anyone have any experience with this.
No direct experience but in the past have been told when I asked about it that a good paint sublayer is required for the wrap to adhere correctly, etc. I was told that a failing paint layer was not a good base to install a wrap on top of.
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
300hp 1800lbs is the goal
Plastidip
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
A wrap is not a bad idea although it only provides a temporary solution.
Not a great solution if you plan to keep the car outside. You’ll get shrinking of the vinyl if you live in a place that has seasons and surface rust along the edges where it shrinks and pulls.
Vince '82 930 ROW coupe bbs motorsport wheels of various vintage/style |
Wrapped a Jeep for a few years with great results. Hard to repair damage, but harder to damage than paint. I did prep and prime before covering so may have improved my results.
