Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
New headlight install problem.
So I am trying to install new flat six Headlights on my 1975 911s . Problem is there isn’t much left of the protruding part of the trim ring lip that circles the headlight bucket . At the top of the bucket there needs to be a piece about 1” wide that the trim ring , in my case the full assembly hooks onto to hold it in place while the bottom retaining screw is installed. Any ideas on how to make this happen ?[img]http://forums.pelicanparts.com/uploads26/IMG_71331710200572.jpg[/img
Old 03-11-2024, 04:47 PM
E Sully's Avatar
Ed
1973.5 T
Old 03-19-2024, 08:01 AM
Bill Douglas's Avatar
I hook the top into place then push the bottom into place. Then while pushing down firmly I put the retainer screw in the bottom. It seems to work and don't be afraid to be heavy handed with it.
Old 03-21-2024, 11:37 PM
make sure the seal is oriented correctly....I can't remember perfectly, but there is one part that goes over the flange that is not immediately obvious - get it backwards and it is headlight hell.
I can't find the thread this is discussed, but for me, once I got the correct seal (there apparently are fatter ones and skinnier ones), my H4's went in smoothly, although pushing like hell is part of the process.
D.
Old 03-29-2024, 10:21 AM
It's going to be a struggle to get those headlamps to properly seat with the thickness of that seal. I had the same issue with my H4's, but here's the trick:
Use the headlamp to body seals for the 356 as they are slightly thinner (sold by our host under part # PCG-631-115-00-OEM). Once installed they look identical to the 911 seals and nobody will ever know.
Old 04-01-2024, 07:45 AM
You may find some helpful info in this thread:
Audette headlamp fitment difficulties
Comment about the seal above is true. This is generally a **** way to mount a headlamp, but a thinner seal does help, as does the technique also mentioned above.
'80 SC Targa
Avondale, Chicago, IL
Old 04-01-2024, 08:57 PM
