LinkBack | Thread Tools | Rate Thread |
Surface Rust - Temporary Protective Measures Until I Can Fix Properly?
Just posted to 944 forum but will do so here also - that I have a bit of surface rust on the bottom rear of the passengers side front quarter panel, and will not have time to address this properly for another month or so.
Is there anything I could be doing in the meantime to protect this area until I can fix it properly? Spray with WD-40 every few days? Something else? Thanks! |
dkbautosports.com
sadly there really is no easy way to stop rust unless you just repair it correctly from the start.
you could brush some rust encapsulator but things like this I have found don't do much. |
Thread Tools | |
Rate This Thread | |
