Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
super9064's Avatar
rust inhibiter options
I am striping my 911 down to bare metal prior to sending it to the body shop, my question is, is there something other than primer, or WD40 that I can put on the metal to inhibit corrosion while I finish other areas?
Old 02-25-2008, 01:33 PM
3.2 CAB's Avatar
What year/model, etc. Is it a galv. tub or not??? Did you mean, WD-40? If so, NO!!! Need more info, there are specific products for various applications. Please don't start spraying water displacing products on that bare metal finish. Your painter will want to do things to you if you do that. Get with your painter and ask him what he wants you to use for temp. protection.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 02-25-2008, 02:11 PM
gestalt1's Avatar
i saw this stuff on Trucks! (one of those spike tv car shows on the weekend). it seems to be just the stuff, i'm going to try it for the same reason you are.
http://www.picklex.com/
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 02-25-2008, 03:35 PM
Originally Posted by super9064 View Post
I am striping my 911 down to bare metal prior to sending it to the body shop, my question is, is there something other than primer, or DW40 that I can put on the metal to inhibit corrosion while I finish other areas?
The best thing you can use is good self etching primer. You can get in either a rattle can style or a conventional two part setup (Dupont Vari-Prime works really well). Usually what I do is prime the entire car in self etching and then go back and regrind the areas I intend to bodywork. Getting protection on bare metal is essential since even in a dry garage surface rust can start to form within a day due to the humidity in the air. Please do not use WD-40 as it will cause big paint contamination problems for your painter.
Old 02-25-2008, 06:42 PM
If it is for a short period of time and no other sources are available, you can use some rustoleum spray can, it is thin enough for your body and paint guy to remove with little effort, and it will hold moisture for a while.
"EVER SINCE EXCUSES WERE INVENTED, EVERYBODY IS PERFECT"
http://axiom-motorsports.com/
Rudy Ruano, Operations Manager.
Joseph Toliva, guy who signs my check
Old 02-26-2008, 06:30 AM
rw7810's Avatar
PickleX is a very good product for what you are looking for. Google it up or search on this forum:http://www.autobodystore.com/forum/index.php
Robert Williams
70' 911T
Old 02-26-2008, 12:05 PM
Nitrometano's Avatar
I do exactly the same.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 02-27-2008, 04:45 PM
Classic's Avatar
I've got some panels coated in Picklex which show no signs of surface rust after 6 months, and i live less then 500M from the beach.
I'm a bit slow with bodywork.
Ask your painter what primer he/she is going to use as you can't use etch over the Picklex as it reacts with the zink phosphate coating.
Classic 1969 911T
Old 02-29-2008, 01:22 AM
What is your opinions about the Por15 rust encapsulator? This will work great in places that have been rusted that was brushed or sanded away (removed)?
1972 911T
Old 03-16-2008, 09:51 AM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Does the Picklex need to be removed before priming and painting, or is it good to go?
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 03-19-2008, 09:55 PM
flatsixcrazy's Avatar
X2. I kept the car dry after piklex for 4 months, no surface rusts.
http://flatsixcrazy.tripod.com/1972_project/index.album/trying-on-964-tail?i=8
Andy
Old 03-20-2008, 10:29 AM
rw7810's Avatar
emptyo - according t pickleX, it can be painted right over. I have had no issues with this.
Robert Williams
70' 911T
Old 03-20-2008, 11:21 AM
I'd scratched the picklex before I put primers over it though.
http://flatsixcrazy.tripod.com/painted_72_project/
Old 03-20-2008, 11:31 AM
Rennch on YouTube
rennch's Avatar
Does the picklex go on clear? Is that what I'm seeing there?
Michael O'Neal -
Old 03-20-2008, 03:10 PM
rw7810's Avatar
Yes, it sprays on clear, you let it sit 2 minutes and wipe off. No need to scatch or scuff prior to paining. Allot of info here, search on pickleX
Robert Williams
70' 911T
Old 03-21-2008, 06:01 AM
Hmmm.. I talked to Len when I repainted my 72 last year and he to go over the picklex surfaces with a 3M pad before primers. But then, my situation was that I left the car in picklex too long. Your mileage may vary.
Old 03-21-2008, 06:18 AM
rw7810's Avatar
Well if that is what Len said, then I believe that would be correct. Sorry
Robert Williams
70' 911T
Old 03-21-2008, 06:39 AM
