Fender replacement....
So I removed my fenders on my 75 911s, was cleaning up some minor rust.
Question is what do I put between the fenders and the body before re-assembly....i removed a silly puddy like substance during removal. Any tips for getting it to all line up again? Thanks |
abit off center
You can buy the ribbon tape that goes there, or make a rope of plumbers putty, that works too.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Ribbon tape...can you provide more info or a link?
abit off center
Give PP a call, I cant find it in their catalog but I think they carry it, its like a sticky putty tape and it comes in a 5 meter roll.
moliver,
I've read posts of people using a 3m product. I think this is it: http://autobodystore.net/Merchant2/merchant.mvc?Screen=PROD&Product_Code=3M8578&Categ ory_Code=JASS I tried doing a search but couldn't find the right thread. I remember it being buried pages down on an RSR conversion post. Hope this helps, maybe someone esle with more knowledge will chime in. Matt |
Thanks for the link, I was looking for something similar but couldn't find it.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
So, has anyone put a fender on dry?
I Por15ed both mating surfaces...and tossed the fender on and don't really want to take it off to goop it up and reinstall it. Not being lazy but maybe a bit...does the goop trap moisture? Where going on dry might keep things a little dryer? Just looking for some comments and experiences. Car is going to be a nice weather weekend drive...and maybe some track. |
I don't see a problem with putting them on as long as both mating surfaces are protected. IMO, Vw/Audi/Porsche used way to much seam sealer on the fender mating surfaces. An alternative could be to use some good quality undercoating or use the Wurth sprayable seam sealer. Both can be applied after the fender is installed. I prefer the Wurth seam sealer because it can reproduce the factory look inside the fender/cowl joint.
