Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
68Sporto
MrJTP's Avatar
Denver/Boulder source for PPG paints
Hopefully I will have all the sheet metal I need to have the bottom replaced on the tub of my 68. In the meantime I would like to start stripping and primer coating the miscellaneous smaller parts. After several phone calls I haven't found a PPG supplier. Anyone know of one in the Denver/Boulder area?
Also, if you know of a plate shop that will rechrome small parts (bumper horns, door handles, etc) I'll be looking for that soon as well.
Tony
Porsche owner since 1967
1998 Boxster
1968 911 Sportomatic project
Old 04-17-2008, 12:38 PM
http://corporateportal.ppg.com/NA/Refinish/ppgrefinish/9-0-Locator/default.htm?searchType=17&Zip=80301
O2 In Sully We Believe
Old 04-17-2008, 04:15 PM
68Sporto
MrJTP's Avatar
Excellent. Thanks Mark.
Tony
1998 Boxster
Old 04-17-2008, 04:19 PM
You're very welcome, good luck with your project and take pics!
Old 04-17-2008, 05:48 PM
joefrantz's Avatar
I use Pro Painters Supply on Sante Fe Drive in Englewood.
Joe
Joe Frantz
73 911 T
Old 04-17-2008, 09:23 PM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Hey Tony,
I need to place an order too. Maybe we can combine and share some of the cost of the reducer/primer, etc...
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 04-18-2008, 01:47 PM
68Sporto
MrJTP's Avatar
Thats a good idea, I'll probably be investing in primer in late May. Hopefully I'll have everything ready to go by then.
Tony
1998 Boxster
Old 04-20-2008, 07:56 AM
What primer do you guys have in mind?
"EVER SINCE EXCUSES WERE INVENTED, EVERYBODY IS PERFECT"
http://axiom-motorsports.com/
Rudy Ruano, Operations Manager.
Joseph Toliva, guy who signs my check
Old 04-20-2008, 09:56 AM
Rennch on YouTube
rennch's Avatar
This kit actually comes highly recommended by my paint and body guy, and he's done a few pebble beach restorations.
http://cgi.ebay.com/EUROCOATE-AUTO-PAINT-2K-URETHANE-ALL-IN-ONE-KIT-144-95_W0QQitemZ260230501030QQihZ016QQcategoryZ45046QQ ssPageNameZWDVWQQrdZ1QQcmdZViewItem
Michael O'Neal -
Old 04-20-2008, 11:04 AM
Rennch on YouTube
rennch's Avatar
Hey Rudy,
Can you give me a breakdown of what PPG products I'll need to prep and paint my car? It turns out that I have a good source for PPG at a discounted rate. Ideally, I'd love "Get 3 quarts of PPG 6579 Hi-Build Primer, 2 quarts of PPG 568 Clear, etc. I'm looking for a basecoat/clearcoat setup, and I have fiberglass to paint. I'm hoping for a high end clear, or something along those lines. Any thoughts? Thanks!
Michael O'Neal -
Old 04-20-2008, 11:21 AM
68Sporto
MrJTP's Avatar
I was planning on using DP40.
Tony
1998 Boxster
Old 04-20-2008, 04:23 PM
Michael, in my opinion, I'd stay away from ecomonic primers, remember, they are the base of your finish job, the PPG products I use are NCP primer, it is reduce 2 to 1 with NCX 285. it is a good all around primer, does not need additives for using on fiberglass, it is a very high build and with a little imagination, it can be used as a sealer, it does smell like a hang over though. As for paint, DBU for base coat, since it is gonna bea solid color (you are stil going with grey, right?) and for clear, I believe your area is stil allowed to use DCU 2021. with this products, you will have a great finish with little effort. they are very easy to use.
No body ever called my welding porn, thanks !!!
Tony: DP40 is too thin to use as a primer surfacer.
Old 04-20-2008, 05:42 PM
68Sporto
MrJTP's Avatar
Rudy, I must have mis-read earlier posts. I assume then that I should go with the same process you just suggested to Michael.
Tony
1998 Boxster
Old 04-20-2008, 05:53 PM
Rennch on YouTube
rennch's Avatar
Thanks Rudy. The message I got from my guy was that they use PPG-Nexa Autocolor. I have never heard of Nexa, but I'm assuming PPG is pretty standard.
Michael O'Neal -
Old 04-20-2008, 05:54 PM
Rennch on YouTube
rennch's Avatar
Also, Rudy, any thoughts on quantities?
I'll be doing door jambs, but no trunk or engine compartment, or interior.
Michael O'Neal -
Old 04-20-2008, 05:56 PM
Tony: if those products are available to you, I recommend them. for us in the L A area no longer available. DP is a very good bare metal primer, NCP 280 is also very good and can be applied without a self etching coat.
Michael: every brand of paint has 2 or 3 lines of products, Diamond and Owni are the lower quality of of Dupont and PPG, the ones I recommended are top of the line, ask your guy about them an see if they have them, as for quantity, I always get a gallon of paint and clear, just in case I need to do a touch up or go over and area I am not happy with.
Old 04-20-2008, 06:18 PM
Rennch on YouTube
rennch's Avatar
Thanks Rudy.
It looks like I'll need:
NCX 280 Primer / surfacer Quantity: ?
NCX 285 Hardener, Quantity: ?
Reducer?
DBU Base Coat, Quantity: 1 Gal
DCU 2021 Clear Coat, Quantity: 1 Gal
Does this sound about right?
Michael O'Neal -
Old 04-20-2008, 06:26 PM
68Sporto
MrJTP's Avatar
Rudy, I have to admit that its been 25 years since I painted a car. Things seem to be more complicated now. I will be painting on bare metal. After I've done all the cleaning, etching, cleaning, etc. So, do I use the DP on the bare metal then the NCP/NCX for the high build?
Michael, what shade of gray are you going to use. My plan also was to use a solid gray. Must be a Boulder thing; I lived there for 20 years before I retired from Ball.
Tony
1998 Boxster
Old 04-20-2008, 06:36 PM
NCP280 1 gallon (doing the whole car plus fiberglass parts)
NCX285 2 quarts, it is reduced 2 to 1 ( buy 1 quart first and see if you need more later, it is expensive)
DBU base coat 1 gallon
DBRR 1170 reducer 1 gallon ( it is reduced 1 to 1)
DCU 2021 1 gallon
DCX 61 1 quart
DT870 1 quart (reduction ratio 4 to 1 to 1)
If I miss a letter or a number, I will let you know as soon as possible.
Old 04-20-2008, 06:37 PM
Rennch on YouTube
rennch's Avatar
That's so perfect. I'll be calling the guy tomorrow for pricing. Thanks!
Michael O'Neal -
Old 04-20-2008, 06:43 PM
