At the track = great day
Bolt size for securing rear wing to trunk lid
I have a '84 911 Carrera with a whale tail and the whale tail is not secured across the rear of the trunk lid (gotta love POs). I see that there are 5 screw / bolt holes already drilled to secure it, but I don't know the sizes of bolts and washers I should buy to secure it.
After some trial and error I think I can use a 4mm bolt/nut/washer combination to secure it however I'd like to know for sure if this is the correct hardware to use or not.
Lane 2011 Volkswagen Jetta SportWagen TDI Looking for another sports car.. |
I figured I'd update this since I finally got around to fixing the wing... Happened when I pulled off the wing the lip where the screws / bolts go into had been chipped and broken off. I had to re-fiberglass the lip then drill holes into it.
I just used some small bolts and washers to hold the rear of the wing to the deck lid.
Thread Tools | |
Rate This Thread | |
