Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
When to use primer
I have a straight white clean fender to put on my silver car. Do I need to primer it first or just sand and apply the new paint?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 11-07-2008, 09:53 PM
Anyone?
Or is the answer already here and I missed the thread?
Can someone link me to it?
3-924's (Sold)
1967-912 (Traded)
Old 11-09-2008, 03:56 PM
I can see that this question was not clear.
Should I put primer on the white fender or just paint it with silver after sanding?
If I should use primer, what primer should I use?
When I sand, what grades of sandpaper should I use?
BTW, this is not a trick question.. I really don't know much about paint.
3-924's (Sold)
1967-912 (Traded)
Old 11-09-2008, 04:02 PM
abit off center
cgarr's Avatar
I will tell you what I did. When I repainted my black Carrera the only thing I primed was the spots that had filler, otherwise I just sanded the original paint and shot it.. I used a single stage paint, I don't know if prep would be different with a base and clear?
Painting this Weekend
______________________
Craig
G2Performance
Old 11-10-2008, 05:01 AM
3.2 CAB's Avatar
Good, factory paint is a good base primer itself. IF, it is in good shape. No rock chips, cracking, checking, flaking, etc. If the paint is good and no damage, some have just used a scuff pad, and then a tack rag, to get rid of what little dust may be there, then prep-sol, before shooting the color. I have stated somewhat simplified prep instructions, but hopefully you understand what I am trying to relate to you. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 11-10-2008, 08:33 AM
Schumi's Avatar
I recently shot two stage Dupont Chroma-based paint using sanded factory paint/primer (in fair condition) as the primer. Results were good.
M
Old 11-10-2008, 08:08 PM
