Converting short bonnets.
Start with clean short bonnet and unroll the leading edge
![]() Make up a new leading section and fit into place ![]() Make up an inner section ![]() Modify the catch so it still fits the 'short bonnet' slam panel ![]() Fill and prime ![]() Paint and fit to car - long steel bonnet - short bonnet front/slam panel ![]()
I would rather be driving
Well Done! I assume that is an SC/Carrera backdate.
Are those Damon's (Series900) turnsignal filler sections? Maybe you have a similar source on the other side of the pond.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
converting
This is brilliant! !
Well done brillant and no mod to front panel .
Can someone start making these ! I will buy the first one!,,
Has anyone done this?
Anyone knows where to find the extensions? I dont have the ability to make one
"It's only temporary unless it works" 1974 911s turbo-look stock 2.7 engine "Dirty Martini" 1953 replica 550 spyder built from the ground up, EJ25 engine Speeduino ECU |
I imagine you could PM Chris. He probably has them at his shop. I purchased his sunroof delete panel earlier. He boxes and ships them over.
Kurt
2010 Carrera S GONE 2022 Cayman T 2007 GT3 1988 Carrera |
Are these extensions available to buy?
Thanks, Dave 3 Things To Live By - You can't be Too Rich, Too Thin, or have Too Much Horsepower!
