Floorpan replacement
When drilling out spot welds what do your suggest for instances where too much material has been removed from the good piece? Should i cut it out and replace with a strip of new metal?
This is a 90 degree, maybe 10mm edge. I'm learning as I go, unfortunately. Thanks!
Bondo sucks. |
1980 911 SC
I can't tell what it is you are working on, but, I try to drill from the side I don't need, so the peice that I do need will have the little nubs left on it. Also, you should only be drilling thru one layer of sheet metal. You need to slow down when you think you are almost thru the first layer.
![]() If you are good at welding sheetmetal that peice can be fixed.
Life's a Beach |
I'm finding it hard to avoid this with certain pieces like the sill area of the rockers. My plan is to weld on replacement metal.
Sean 1982 SC D-Stock #372 NASA GTS2 1971T restoration in progress, read about it here: http://911restorationmadness.blogspot.com/ |
it is easy to drill through both panels, i actually cut with a sawsall along the flange edge to get the panel off. the flange had 2 layers of sheetmetal on it so i used a grinder to wear away the floorpan layer. it was a lot of work but the flange was in good condition when done. i would cut the flanges off and weld in new formed metal to replace if there is too little material left. what you show in the photo will get blasted away when welding to the new pan.
BMW 128i 73 rsr clone - sold 68 912 project to become 911r (almost done!) |
dkbautosports.com
like sailchef stated ! there are alot of good spot weld cutters out there but like with most tools it will take time to learn how to use them and see how they work . first and formost slow down your not in a race ! i would weld a patch on that spot . but if your not a good welder there is a chance that you can make a bigger mess . so stay in your comfort zone .
