Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
pr944may's Avatar
Pelican Parts How to remove the targa outer rollbar
I am disassembling the car for a paint job. Everything going OK.
BUT GOT NO IDEA HOW TO PROCEED TO TAKE OUT THE TARGA CENTER CROSS BAR. Can someone give me some advice please.!!!
Albert
911 SC 1983 :
Old 11-22-2010, 06:43 PM
The stainless bar has 4 x6mm studs passing through the rear fender holding it in place,you will find 4 x6mm nuts under the rear fenders two on each side,directly under the bar,you may have to remove the undercoating to gain access
Now its been long time since I removed one of those,not sure what keeps it tight on top near center???
Cheers
Walt
Old 11-22-2010, 08:46 PM
Walter36 is correct, directly below the Targa script are two 6mm studs (on each side) that go through the body and are accessible from the wheel well. You will need to remove the rear tires to reach the nuts. You are going to want to soak them with a penetrating oil for a day or so or you will snap the studs. Ask me how I know. In addition there are also several small screws (8 or 10) on the forward edge of the cover behind the targa top seal that will need to be removed. You should then be able to lift the cover straight up and off.
Good luck.
DR
Old 11-23-2010, 05:17 PM
pr944may's Avatar
Tomorrow I'll check everywhrwere and follow your instructions Thanks, guys
Albert
911 SC 1983 :
Old 11-26-2010, 05:53 PM
Hey walt how did you make out/
Old 11-27-2010, 05:29 PM
targa bar
hey thanks drcoastline, i am about to do the same thing and could not find the bolts holding the cover on after taking out the small screws at the seal.
Old 11-30-2010, 08:18 PM
No problemo PacificP. good luck.
Old 12-03-2010, 05:33 AM
pr944may's Avatar
Hi again :I find and remove the 6mm screws in the wheel area that was ok and find two small in ther door edge area. WHEN YOU SAID TO REMOVE THE TOP SEAL. DOes it is glued to the car or does it has any other screw or thing to be aware of. Should I just pull it off or there is any particular way to do it please advice. Thanks.
Albert
911 SC 1983 :
Old 12-19-2010, 11:02 AM
The seal is glued on you can coax it off gently. I wouldn't just pull it off unless it is bad shape and going to be replaced.
Old 12-19-2010, 05:07 PM
Mr Percival!
dt-911's Avatar
aaaaaaaaaaaaaaah!
Old 06-24-2011, 08:01 AM
Porsche also uses a sealant between the stainless cover and the stamped steel bar underneath. You will have to pry the cover up from one side, then go around on the other side- work it back and fort a couple times, the pull it the rest of the way off.
The back window does not have to come out to perform this operation
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 06-24-2011, 05:15 PM
Mr Percival!
dt-911's Avatar
If the studs break when undoing the nuts on the wheel well is there a fix or is it new bar cover time?
Old 06-28-2011, 08:22 AM
no problem- get someone experienced in Tig, to weld some studs on for you. take care to keep the outer cover cool, so you don't get bluing from the heat
1970 911 Targa "ST"
Old 06-28-2011, 08:24 AM
Mr Percival!
dt-911's Avatar
Ta. It might make the job a little harder when I get to it, but I will keep my fingers crossed!
Old 06-28-2011, 07:58 PM
