Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
VFR750's Avatar
Local Rust Pits - primer questions - edited
Here is my new Winter Project:
Not as extensive as others, but it needs to be cleaned out.
OK, I get it... new topic.
Rust is being removed by a small grinding wheel and carbide burr. The general surface rust was scuffed off with sand paper, but the pits! Ugh they were deep. So they had to be ground out. I have time and the deep pits are only in a few locations thankfully, so going the sand blasting route is a little overkill.
Looking at the posts and the 101, I'm still a little confused since most posts refer to things like "DTM" "RM" "EP" and other abbreviations that just make it hard to figure out what is being refered to. I've done a lot of searching but without a spreadsheet, I am losing track of all the suggestions. Guess I need a spreadsheet...
What is DTM? and Why is it good?
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 12-28-2011, 09:37 AM
VFR750's Avatar
Oh, DTM = "Direct to Metal"
RM = R-M a brand name...got it.
Mike
Old 12-29-2011, 06:22 AM
EP= Epoxy Primer
Good work Grass Hopper you learn very quickly.
Old 12-29-2011, 11:57 AM
rw7810's Avatar
Mike - PickleX20 is a good rust converter product you could also use prior to priming. Go here to read about it. I used on my repaint as is Fishcop. Autobodystore Forums
Robert Williams
70' 911T
Old 02-25-2012, 08:40 AM
