Local Rust Pits Repaired!
I just finished buffing out my local repair!
![]() Very happy with the Results. Here is the in process shot. I used an airbrush for all layer:, EP, Bondo (did not spray, obviously...) , EP top coat, 2K Urethane Primer, Base Coat and 2K Clear Urethane. Airbrush worked great! ![]() Before
Mike '82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar. Last edited by VFR750; 03-19-2012 at 03:50 PM.. |
Bird. It's the word...
Nice work!
John Forcier Current: 68L 2.0 Hotrod - build underway |
Slippery Slope Victim
Very nice. Blending is a pita, looks great.
MikeČ 1985 M491 |
Using an airbrush made it easy as it allowed a very thin blend line. 1500 wet sanding and rubbing compound faired it in nicely. Plus the urethane color matched the two previous resprays. That was important too.
