Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Rust in corner(s) of windshield... help!
hey all. searched around for a bit... I'm sure this has been addressed in the past, maybe someone can point me in the right direction. what should I do about this nasty rust?
appears the p.o. may have tried to cover it up with some kind of quick fix..
open to suggestion! thanks guys p.s. I love this forum!
85 carrera 3.2
Old 05-13-2012, 02:36 AM
Yep it's been addressed quite a bit. You will need to pop the windshield out and remove the front fenders for a proper repair. The rust is most likely three times the size you see in the photos. I would venture a guess from the photos that the rust has probably rust ta hole in the panel and water is entering the passenger compartment and the trunk area.
You will need to weld in a repair panel similar to this. You could make your own of sheet metal. Obviously the panel will be trimmed to fit the repair.
Be prepared if the rust is there it is lurking in other areas of your car as well.
Old 05-13-2012, 03:50 AM
just a thought... why would u let it go this far?????????
Old 05-14-2012, 06:21 PM
actually i bought the car like this, almost a year ago and it hasn't gotten that much worse (that i can tell superficially) but i know it needs attention and this place is full of experts!
85 carrera 3.2
Old 05-15-2012, 10:28 PM
thanks for the quick response! is that part something that pelican sells?
85 carrera 3.2
Old 05-15-2012, 10:30 PM
Yes, but it looks like it is temporarily unavailable. Look on the for sale section you may get lucky and find a car that is being parted out. There is another source for sheet metal but at the moment the suppiers name escapes me. Sorry.
Old 05-16-2012, 04:54 AM
Gillies's Avatar
Try Restoration design up in canada. Its item # 17
911/912 Exterior: Restoration Design
Gilles...
1970 Targa 911T
Old 05-16-2012, 01:54 PM
Tired Member
DaddyGlenn's Avatar
Start poking around. There is more, guaranteed. Mine didn't look that bad.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/565023-talk-me-through-rust-repair-please.html
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 05-16-2012, 06:29 PM
That's it restoration design. Thanks Gillies.
Old 05-16-2012, 08:09 PM
