Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Took out the rest of the parts that need to be powder coated.
Cleaning these two was a pita!
And the rest of the parts...
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 01-11-2016, 07:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #201 (permalink)
wachuko's Avatar
As it sits in the garage this morning... parts left at the local powder coating place (BNJ Powder Coating).
With the front strut supporting mount removed, I will need to scrape all that rubberized gunk out... I have some paint left, not sure if I will paint that back to the color of the car or just use some semi-gloss black in the area (masking the rest, of course)
Drive safe!
1967 - Porsche 912
Old 01-12-2016, 04:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #202 (permalink)
Banned
cool, project! looking good.
Old 01-12-2016, 09:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #203 (permalink)
wachuko's Avatar
Cool
Thank you!
On other news. Powder coating parts are done! On my way to pick them up. Also a few boxes from Pelican arrived today as well... the rest should be here in a day or four.
Drive safe!
1967 - Porsche 912
Old 01-14-2016, 07:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #204 (permalink)
wachuko's Avatar
- I should be able to work on installing some of this back on Monday
Drive safe!
1967 - Porsche 912
Old 01-14-2016, 09:09 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #205 (permalink)
Following! This is awesome.
Old 01-15-2016, 01:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #206 (permalink)
wachuko's Avatar
Thank you! Looks like all the parts came in while I was out this weekend. :thumbsup:
Time to work on the car again! Here, a photo after taking everything out of several boxes and placing just the parts in a single box... now to the garage!
Drive safe!
1967 - Porsche 912
Old 01-18-2016, 08:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #207 (permalink)
wachuko's Avatar
And unpacked all the powder coated parts...
Drive safe!
1967 - Porsche 912
Old 01-18-2016, 08:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #208 (permalink)
wachuko's Avatar
Unhappy
Humm... Ordered what I thought was the correct torsion bar but it looks nothing like the original... calling Pelican.
Strange because the part number in the box and the description all points to the correct part, but no way this can fit where the old one is... Here, it has two labels...
Drive safe!
1967 - Porsche 912
Old 01-18-2016, 08:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #209 (permalink)
wachuko's Avatar
Looks like I got 27mm rear torsion bars
Too bad these are not 28mm or I would have kept them for the rear...
Drive safe!
1967 - Porsche 912
Old 01-18-2016, 09:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #210 (permalink)
wachuko's Avatar
This was easy... Elephant Racing Strut Top Camber Plate Bushings
Mounting the ball joints
I will install the other bits later...need to check what the torque value is for that nut...
Also installed the rubber bushing in the a-arms.
Drive safe!
1967 - Porsche 912
Old 01-18-2016, 10:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #211 (permalink)
wachuko's Avatar
I think that I need to wait for the instructions of the torsion bars to find out the correct angle for the bushings?? I need to look at the book... let me insert the bushings while I get the book...
Drive safe!
1967 - Porsche 912
Old 01-18-2016, 11:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #212 (permalink)
wachuko's Avatar
Removed all the gunk from the shock tower area... painted it flat black on top and underneath to protect it from rust.
Removed steering rack. Forgot to order the rubber bushing with the bearing inside...will order tonight with a few more things... Removed the tie-rod ends from the rack.
Installed the mesh and frame at the end of the hood...used the wrong screws but those are just in there until the correct ones arrive.
Drive safe!
1967 - Porsche 912
Old 01-18-2016, 05:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #213 (permalink)
wachuko's Avatar
Cool
Only held in place with one bolt... will align it better, and install the other three bolts, tonight after work...
Also forgot to mention that I got the original rubber gasket for the fuel sending unit and it worked like a charm... sometimes the best part is the original part... the gasket that was in the boxes of parts that came with the car would not align correctly . New nuts and washers are on their way. I have a new plug cover... forgot to get this one to powder coating. I will just install the new one that I have in yellow zinc finish.
Drive safe!
1967 - Porsche 912
Old 01-19-2016, 05:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #214 (permalink)
wachuko's Avatar
Can't do much until the rest of the parts get here...so baby steps. Installing the spacer on the strut mount.
Rinse and repeat...
Drive safe!
1967 - Porsche 912
Old 01-23-2016, 12:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #215 (permalink)
wachuko's Avatar
These are done...
Drive safe!
1967 - Porsche 912
Old 01-23-2016, 03:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #216 (permalink)
wachuko's Avatar
For a minute there I thought the hubs were painted black... It is all accumulated brake dust...
More cleaning left to do... I should have used the soda blaster to begin with...
I waste so much time installing parts just to look at them...
Drive safe!
1967 - Porsche 912
Old 01-23-2016, 08:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #217 (permalink)
wachuko's Avatar
Cool
Preparing the hub for the bearings...
I am doing my own yellow zinc with the bolts I buy locally... Sumerge the bolt into the prep liquid, wait 20 seconds, rinse in clean water, dry with heat gun (to avoid the wait), and voila!!
I did not know that the hub were specific to sides... These were marked as such...
Done! (well...still need to install de grease cover)
Drive safe!
1967 - Porsche 912
Old 01-24-2016, 06:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #218 (permalink)
wachuko's Avatar
Originally Posted by amber lamps View Post
Very nice. Tell me about the zinc process and sorce for the kit. I'd be interested in that as I am sure others would be.
Just to be clear... I am only using yellow chromate to get the finish on new zinc plated bolts that I buy locally... Yellow zinc plating is a two part process... first you zinc plate the bolts and then you run them by a solution that gives it the color.
When I ordered the zinc plating kit from Eastwood (btw, this is still in the box and have not used it...) , I also ordered some yellow chromate from Caswell... ...mixed some distilled water and 2 oz of this product....
I felt like I was dealing with plutonium...this came inside two boxes, and then the can was in a sealed bag...
Let's try a few parts... those new nuts look clean...
Rinse with clean water and dry with a heat gun at low setting...
Does not work on anything but newly zinc plated parts...
Drive safe!
1967 - Porsche 912
Old 01-25-2016, 05:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #219 (permalink)
Ferrino's Avatar
Cool find on the chromate solution! How do the parts look next so factory zinc/cad plated stuff? I guess it depends on how long you soak for and the original plating. They look good to me!
Very nice way to treat fasteners from the hardware store and those annoying Porsche parts that don't get the yellowing treatment.
Old 01-25-2016, 04:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #220 (permalink)
