A few more from today. All glass comes out Saturday. I then remove the dash to recover in leather and get the instrument/ gauges off to have him paint the instrument panel the same color as the exterior: http://i151.photobucket.com/albums/s...S/IMG_1854.jpg http://i151.photobucket.com/albums/s...S/IMG_1853.jpg http://i151.photobucket.com/albums/s...S/IMG_1856.jpg http://i151.photobucket.com/albums/s...S/IMG_1855.jpg http://i151.photobucket.com/albums/s...S/IMG_1852.jpg http://i151.photobucket.com/albums/s...S/IMG_1857.jpg http://i151.photobucket.com/albums/s...S/IMG_1858.jpg |
While Alejandro worked on fixing the rust in the lower part of the front fenders, I took out all the heater/blower parts and removed the dash and instrument cluster.
Before: http://i151.photobucket.com/albums/s...0RS/Body-6.jpg Work in progress: http://i151.photobucket.com/albums/s...RS/Body-10.jpg And my work... Easy to just remove stuff... the tricky part is to be able to put it all back together when the time comes :D http://i151.photobucket.com/albums/s...0RS/Body-8.jpg http://i151.photobucket.com/albums/s...0RS/Body-9.jpg http://i151.photobucket.com/albums/s...0RS/Body-7.jpg |
Found a few photos of the color we want for the project:
http://i151.photobucket.com/albums/s...marineBlau.jpg http://i151.photobucket.com/albums/s...d3fa67b1b3.jpg What the tank will look like once it is done... TRE should be shipping the Center Fuel Fill kit any day now. http://forums.rennlist.com/rennforum...1352091664.jpg And the exhaust system I want to install... I can't use the new oil line that the car came with for this setup. http://i151.photobucket.com/albums/s...1349807419.jpg Part numbers for the oil lines needed: 911-107-739-10 http://i151.photobucket.com/albums/s...1110773910.jpg and 911-107-729-10 http://i151.photobucket.com/albums/s...1110772910.jpg |
Center filled kit came in today!!
http://i151.photobucket.com/albums/s...S/DSC06739.jpg And a few photos of the work on the front fenders... rusted areas cut, and new metal in place. http://i151.photobucket.com/albums/s...S/Fender-3.jpg http://i151.photobucket.com/albums/s...S/Fender-1.jpg http://i151.photobucket.com/albums/s...S/Fender-2.jpg |
Rennline pedals are in!! Forgot to order the Throttle extensions, duh! I still want a few more items from them so those will come in the next package...
http://i151.photobucket.com/albums/s...linePedals.jpg http://i151.photobucket.com/albums/s...0RS/Pedals.jpg |
Alejandro working on fixing the rusted areas...
http://i151.photobucket.com/albums/s...ustareas-1.jpg http://i151.photobucket.com/albums/s...ustareas-4.jpg http://i151.photobucket.com/albums/s...ustareas-5.jpg http://i151.photobucket.com/albums/s...ustareas-6.jpg http://i151.photobucket.com/albums/s...ustareas-3.jpg Looks much better now... http://i151.photobucket.com/albums/s...ustareas-7.jpg The bottom of the passenger side door does not look that good... I ordered the following from our host to repair it: http://i151.photobucket.com/albums/s...ustareas-2.jpg SIC-531-012-10 - Door Skin Bottom 6-inch Repair Panel (Right), 911 (1965-89) SIC-531-026-00 - Door Bottom Repair Panel (Right), 911 (1965-89) |
Damn Money Bags!!
Repair panels for the passenger door arrived. Will take them Saturday to the shop.
http://i151.photobucket.com/albums/s...irpanels-1.jpg http://i151.photobucket.com/albums/s...irpanels-2.jpg |
more More MOre MORe MORE!!!!!!! keep up the great work, cant wait to see how this turns out
Engine stand ready to so that I can split the engine from the transmission and mount it in the stand to have better access. Need to remove broken exhaust bolts, install new (older style) oil lines in preparation for the headers and exhaust.
http://i151.photobucket.com/albums/s...rPorsche-1.jpg http://i151.photobucket.com/albums/s...rPorsche-2.jpg |
Oh boy....:eek: I hope we get it right the first time...
Work has started on the install of the center filled setup... http://i151.photobucket.com/albums/s...S/IMG_1932.jpg |
Car has the center fuel filler installed!! A few photos:
http://i151.photobucket.com/albums/s...3AB097DDEC.jpg http://i151.photobucket.com/albums/s...3AAD5F6AA5.jpg http://i151.photobucket.com/albums/s...3AB2E66EBF.jpg http://i151.photobucket.com/albums/s...3AABEECF74.jpg |
That was the short update... here is the more detailed one...
First measured the center of the hood line... moved that to the tank and drilled the hole in the tank... http://i151.photobucket.com/albums/s...S/IMG_1932.jpg http://i151.photobucket.com/albums/s...dInstall-1.jpg http://i151.photobucket.com/albums/s...dInstall-2.jpg Then marked the hood ( for both of these steps, a plumb-bob came in handy). Alejandro cutting the hole in the hood: http://i151.photobucket.com/albums/s...dInstall-3.jpg http://i151.photobucket.com/albums/s...dInstall-5.jpg http://i151.photobucket.com/albums/s...dInstall-6.jpg Let's test height... remember to use the rubber gasket for the last test.. http://i151.photobucket.com/albums/s...dInstall-4.jpg http://i151.photobucket.com/albums/s...dInstall-7.jpg |
Last few checks before welding in place:
http://i151.photobucket.com/albums/s...dInstall-8.jpg Let's do this... http://i151.photobucket.com/albums/s...Install-10.jpg http://i151.photobucket.com/albums/s...Install-11.jpg After bending the metal around where the fiber glass finishing ring goes... some epoxy to hold it in place... http://i151.photobucket.com/albums/s...Install-12.jpg http://i151.photobucket.com/albums/s...Install-13.jpg |
looking good!!!!!
Back to the project...
I wanted to break apart the transmission from the engine to mount the engine on a stand and be able to work with some broken exhaust bolts, get the oil lines back dated, and have it ready for when I get the exhaust system that I want. I also wanted to inspect the clutch's conditon. Good news is that it was easy to take it apart. And from inspecting the clutch, fork, etc, everything seems to be new. Thank you for those that responded on my previous thread on questions about how to take it apart. First I needed to remove the two tensioning springs... http://i151.photobucket.com/albums/s...S/Tranny-1.jpg http://i151.photobucket.com/albums/s...S/Spring-2.jpg http://i151.photobucket.com/albums/s...S/Tranny-9.jpg Removed the starter, the nuts holding the case to the engine... put the transmission jack... and slide out the transmission. I am so happy that it did not give me a fight. http://i151.photobucket.com/albums/s...S/Tranny-3.jpg http://i151.photobucket.com/albums/s...S/Tranny-4.jpg Clutch fork, gaskets, o-rings, all looks to be new... http://i151.photobucket.com/albums/s...S/Tranny-5.jpg http://i151.photobucket.com/albums/s...S/Tranny-6.jpg Surface rust on the pressure plate... http://i151.photobucket.com/albums/s...S/Tranny-7.jpg And clutch disk also looks to be new... http://i151.photobucket.com/albums/s...S/Tranny-8.jpg Now I just need to move the engine to the stand so that I can work with removing the old exhaust and broken exhaust bolts. |
Looks like a great build. You are making it all look so easy, and working so quick!
Moved engine from hydraulic table to the engine stand. http://i151.photobucket.com/albums/s...einstand-1.jpg http://i151.photobucket.com/albums/s...einstand-2.jpg http://i151.photobucket.com/albums/s...einstand-3.jpg Broken exhaust bolts/studs. Exhaust Stud Repair Tool ordered from Christian... looks like I will make good use of it... http://i151.photobucket.com/albums/s...einstand-4.jpg Lots of WD-40 and hoping these come out... http://i151.photobucket.com/albums/s...einstand-5.jpg |
Oil line ordered (911-107-739-10-M127) :
http://i151.photobucket.com/albums/s...1110773910.jpg Also ordered the Clutch Arm Helper Spring and Backlash Spring for when I install the transmission back to the engine. And I ordered the Expandable Oil Return Tube Kit in case I mess up the return tube next to the oil line... Everything should be here next week. |
| All times are GMT -8. The time now is 09:24 AM. |
