Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Send a message via AIM to kena
Removing anodized color from a Mahle
Maybe someone can recommend a way to remove the color from one of these wheels. I have one spare which was anodized blue and I would like to remove all the color from it back to the magnesium natural color. Would some type of chemical work? Steel wool seems tedius and would not get all the color as the surface is so porous.
Old 06-30-2002, 06:57 AM
Don Haney's Avatar
I have refinished a few sets of Mahle wheels. I was never able to get the blue off either. Most of the time the wheels needed refinishing anyways. Although it may not be the correct finish, I have always used Wurth Silver with good results.
Good Luck,
Don
Don Haney
don@pelicanparts.com
888-280-7799 Ext 305
1991 C2 Tip - Sold
Old 07-01-2002, 06:53 PM
slammed1000's Avatar
Send a message via Yahoo to slammed1000
easy off oven cleaner is what i use to get anodizing off motorcycle frames to polish so i would think it would work for these wheels. use the yellow can not the red..just my 2cents
Old 07-04-2002, 10:55 AM
Roy M's Avatar
Caustic Soda - takes it off a treat. Watch your skin (ie wear thick industrial gloves) but you can actually see it working.
I found the oven cleaners in the UK too weak (Consumer protection legislation again!)
Roy
Old 07-05-2002, 01:06 AM
