Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Plastic media blasting for surface rust ?
Do you recommend plastic media blasting for surface rust ?
Car was stripped with chemical strippers and left without primer, after some years all the body has surface rust.
Old 04-21-2014, 02:57 PM
dkbautosports.com
962porsche's Avatar
it would or does depend on how bad the rust is as to what media you should use .
it also depends on just what car your thinking of blasting . big old cars with a heaver gage metal you can be a little more aggressive with the media you pick .
but the plastic media will be just fine for most surface rust .
Old 04-21-2014, 06:57 PM
962porsche
Thanks for your answer.
I will try to use plastic media and see what the results are.
Old 04-22-2014, 10:16 AM
Banned
There are some exellent brush on chemicals that stop rust and kill the cancer. Google it. Worth a look and they don't eat metal like abrasive products.
Old 05-27-2014, 07:16 AM
dkbautosports.com
962porsche's Avatar
products like brush on encapsulator's do not kill rust it does just as it states encapsulates it .
that type of product has it's uses for things like down inside the rails of a chassis were blasting will not get to .
blasting will not change the gage of the steel at all so eating up your panels by blasting is nothing you would ever have to worry about .
Old 05-27-2014, 04:24 PM
