| Registered Join Date: Dec 2000 Location: philadelphia, pa
				Low voc paint source
			Looking for a source for sunshine yellow L13k low voc paint.
|  07-22-2014, 04:59 PM |
| dkbautosports.com Join Date: Feb 2009 Location: branford ct
			all paints now are of low VOC's !  there is a thing called national standards that set Volatile Organic Compounds (VOC) at a set level and can be no higher . how ever there are states like CAL. and CT that have set the state standards even higher then the national rule or standards . this is done by changing the hardeners and the amount of reducers used in the products . if your buying the products from your area jobber (auto paint store ) then your buying products that will meet the national and state standards . some states like Cal. it's hard to find single stage products but this is because of the jobbers and not the state or fed laws . they just wish not to offer it but it is available and the paint manufactures do make products that are compliant to all the state and national rules . so simply go down to your area jobber and get the products you will need . | ||
|  07-22-2014, 06:00 PM |
