Fender Removal
I would like to remove front fenders on my 73 911 as I continue the teardown. I know that it is bolted on, but is it also welded or tack welded? Will it require any cutting?
Josh |
dkbautosports.com
if the fenders have never been off the car in it's life you will find a single tack weld were you open the door and the top two bolts are at the cowl panel is .
you have to slid a stiff putty knife down between the cowl and the fender between the two bolts location and hit the end of the knife hard to cut the tack weld there . other then that there are no other welds on the fenders . |
Thanks!
