Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Problems with engine lid closure
My rear lid alignment was not quite right so I started to sort it out yesterday. I'm thinking about running without the whale tail so it was removed leaving just the lid. I then removed both shocks and the latching post. I then aligned the lid by adding a shim on one side, removing one on the other and getting it centered just right by moving the hinges on the lid as required. Perfect I thought so I put the latch back on and centered it to the receiver latch, still no shocks. Good thing I went slow when I started to push the lid closed, the upper left corner of the lid started to move over to the left a lot - about 3/16". So I loosen the latch and move as far to the left as it will go and the effect is less but the lid still moves over to the left at the top left. I put one shock back on the left hinge to see if it made a difference and none. So against better judgement, I opened up the holes on the latch so I could move it more to the left. Now I don't have to worry about the lid contacting the body but it is not the way it should be and I need to know why and how to fix this annoying problem. Help please and thanks
1986 Targa Guards Red
2021 MT09 SP
Old 11-24-2014, 09:48 AM
MY lid is also not fitting right. I hope you find out what is wrong maybe I can try the same thing on mine. 82 911 traga
Old 11-26-2014, 07:24 AM
Send a message via Yahoo to rgofast
check for worn or bent deck lid hinges
1969 911TR lightweight, 1850 lb. 245 HP 2.7 short stroke
1973 1/2 911T S optioned sunroof coupe (in progress)
1998 993 Carrera Cabriolet PSS10 lowered E88 cup wheels
1999 996 Carrera Cabriolet
Old 11-26-2014, 10:56 AM
