Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
78-911SC's Avatar
Where not to put high build primer?
So I've done my body work and most blocking and ready to put down my high build primer. My question is where do I put it or should I say not put it. Examples trunk, wheel wells, under both deck lids, door jams, inside door where door cards go and bumpers inside and out. I think the high build primer is for blocking so I'm not so sure it needs to be in those places but thats why I ask. To much time and effort to not do it right. Just for reference it's a 70T.
PJ
78 911sc Targa
70 911T
Old 04-12-2015, 08:27 AM
dkbautosports.com
962porsche's Avatar
most of the time it's not really where your using but why you would need it .
as we all know you would want it over your body work areas .
but if the rest of the finish around your body work areas are in good condition then you would not have to cover the hole panel with it .
but that would be if your using a sealer when your going to do your top coating .
on the other hand if you have breakthrough's in the existing top coat from prepping /sanding it . then you may want to spray 2 to 3 coats of a filler primer down to give you a good flat substrate for your new top coats to go over .
Old 04-12-2015, 10:14 AM
78-911SC's Avatar
962 a follow up if you don't mind. I'm not sure how long it will be before I actually put paint on the car. Should I leave the car with the high build primer after my final block or should I go ahead and put the sealer primer on it? Also am I correct in remembering that on the final blocking of the high build I use 800 grit? What grit would I use on the sealer and how many coats?
PJ
78 911sc Targa
70 911T
Old 04-12-2015, 03:37 PM
dkbautosports.com
962porsche's Avatar
if your going to seal the car you would want to do it wet on wet with your top coating . so no sanding of it !
do you final blocking the car can then sit as long as you want .
if it sits like that (final sanded) for more the 48 hours you would want to hit the hole car quick with a red or gray pad to open up the sand scratches again .
800 is a little to fine of a grit for top coats to really stick to . 400 to 500 or 600 at most is what you would want to sand for top coating .
Old 04-13-2015, 05:40 AM
78-911SC's Avatar
Sorry 962 but confused with the terminology. I think what you are saying is if I'm going to let the car set for a few months or longer before actually going to paint I should do my final blocking of the high build primer with 400 grit and than when I get ready for paint months later put the sealer primer on and than color. I hope I got that right. Wet on wet are you saying the sealer primer than before it's dry I put on the color??
PJ
78 911sc Targa
70 911T
Old 04-13-2015, 06:39 AM
dkbautosports.com
962porsche's Avatar
ok so let me try and explain this better .
spray your build primer . then block the car making it nice and straight .
if you can't get top coat on the car with in 48 hours after you block it you would want to go over every thing with a red or gray sanding pad / this will open up the primer on the car again for the top coats to stick .
at that point you would mask off the car and get it ready for top coat before the 48 hours are up again .
you would want to seal the car so you would use a sealer wet on wet going from sealer to top coat just letting the sealer flash off before you start your top coating .
wet on wet there is no need to sand the sealer .
now there are sealers , primer sealers ,low build primers, medium build primers,high build primers and ultra high build primers .
for wet on wet you would want a sealer . it gives a very thin coat making the car all one color for ez hiding for your top coats and a very flat even surface it aids in giving the top coats some thing to bite into .
Old 04-13-2015, 08:28 AM
78-911SC's Avatar
Very good 962 that makes things a lot clearer in my mind. I won't be doing the top coat so it looks like I won't be doing the sealer either. I'll be using a professional painter that can do the car some justice. I can do all the grunt work. Thanks again for your help along the way or should I say up to this point because there might be more questions. Ha
PJ
78 911sc Targa
70 911T
Old 04-13-2015, 10:50 AM
dkbautosports.com
962porsche's Avatar
I'm more them happy to help any time I can .
Old 04-13-2015, 02:01 PM
