Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
ganun's Avatar
How to flatten paint chip paint blob
Any tips other than being really careful how much paint to apply?
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 11-18-2015, 12:18 PM
Make sure it's thinned enough to flow, use an artist brush to apply and use multiple coats to build it up.
Old 11-19-2015, 08:26 PM
carefully wet sand w/ 1200-1500 grit and buff...go easy!!!
Old 11-19-2015, 11:45 PM
diy83sc's Avatar
^^^ go easy... you can use dish soap as a lubricant to create a surface to float 1200-1500 grit wet-sand paper. I block in onto a paint mixing stick cut down to two inches. The soap helps keep the paper off the paint surface around the paint blob.
To apply touch-up paint, use a toothpick and have patience to only apply as much as the chip will "take". A small amount of paint at the end of the toothpick is enough. Touch the exposed metal and you will see the paint get pulled off the toothpick - capilary action? Wait for it to dry, repeat until you build the paint just above the un-chipped surface. Sand as above.
Old 11-22-2015, 07:04 PM
cary's Avatar
Carefully cut the top off with one of these if you have a big blob. Then wet sand.
Save on Tool Aid 89780 at ToolTopia.com
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 11-27-2015, 06:27 PM
