Go Back   Pelican Parts Forums > Miscellaneous and Off Topic Forums > Paint, Bodywork & Detailing Forum
BobnJoz
Send a message via AIM to bobswei
Undercoating questions?
I started doing research on undercoating my '72 911. I only want to do touch up areas since most is in-tacked. It looks like Wurth underbody sealer is the best match and grey is the correct color, (since beige is not made anymore?) First question, where to find the grey? I checked the Wurth website and they only show the black. Everywhere I look, only black. Next question, Is this easy to blend into the old undercoating or will it be obvious and I should coat the whole underside of the car?
I saw that the spray gun style creates the best match for texture so that is my plan.
Thanks for the help.
Old 08-26-2016, 03:59 PM
dkbautosports.com
962porsche's Avatar
it's not undercoating that is the useless black crap that should never be used on anything .
you want to use chip guard .
U-pol is who makes it for wurth . u-pol offers it in white , gray and black it can be tinted to match your cars color / shade .
you would tint it with acrylic enamel .
Old 08-27-2016, 03:45 AM
BobnJoz
OK, I found the u-pol fairly easily. This will give an original looking finish?
Also, will 1 liter do the whole underside of a 911? I would want to tint it to match the gray/beige of the original undercoat. Looks like I would be getting gray for the gas tank and white for the underside.
Thanks for the response....
Old 08-27-2016, 07:31 PM
They make it in a spray can now. Used it for touch up's and it works great
Old 09-04-2016, 06:01 AM
78-911SC's Avatar
Does the spray can texture look the same as factory? Can the flow be controlled?
PJ
78 911sc Targa
70 911T
Old 09-04-2016, 06:53 AM
dkbautosports.com
962porsche's Avatar
yes some what is does . you have to control the distance and speed plus the number of coats more to get the same OE look but it's very do able
Old 09-04-2016, 01:45 PM
