rust stopper...slow downer or something
83 933 has aboyt a 4x2 in rust spot in rear arch.
I really just want need to stop it but more likely slow it down. Was thinking I would sand it smoothish then put a rust inhibitor on it. I have a small can of por15 and although it has never been opened it has gone through a couple of seasons sitting in a cold garage. So since I need to buy something new anyway I wonder what would be best. Also what level/grit paper should I use? ![]() ![]()
dkbautosports.com
MY GUESS IS FROM RESTORING A NUMBER OF 944'S THAT PRETTY MUCH THE HOLE WHEEL OPENING IS RUSTED TO CRAP !
you will have to get to the back side of the QTR to get some rust treatment between the two panels ( outer wheel house and QTR panel ) or it will just keep rusting . then being open with a rust hole there is no way to keep moisture out . |
Full story on the car. It has a salvage title and was to be a track car by the PO.
I picked it up for 1400.00 INCLUDING tax-title-reg and inspection. It had brand new tires, rebuilt calipers, new pads/rotor/ steel lines. Timing belt/water pump and all new front seals and some other odds and ends. I drive the car to work just about every day unless its raining. Having said that it needs a bit of work in all phases. I bought it to teach my son how to wrench a little bit. I thought the Porsche would be a fun way to learn and I work in a Porsche shop where parts are plentifull. I love the car and so does my son. I love that my kids can climb around it and if it gets scratched who cares. My son has already helped diagnose a no brake light situation and done some basic maintenance. I got a quote to fix the rust. 650 and they were going to cut out a large section, put in new metal and match the paint. While I don't think that price is horrible I just don't think its worth it on a 1400 salvage car. I just want to slow it down and make it look decent. The car stays garage and almost never sees rain. |
dkbautosports.com
get some sem rust seal and get at down between the two panels the outer wheel house and the QTR panel this will slow it down some .
so a salvage doesn't make the car a total POS . so place the worth on what the car is not on the value of a salvage is . this also could be a good chance for the two of you guys to learn some about body and paint . do the repair your selfs . the body and paint forums here are pretty good lots of us are here to help and walk you thru repairs just like this . |
Sorry what do you mean get "between" the 2 panels?
dkbautosports.com
you have to get to it from the inside of the car . so you can get the rust seal between the outer wheel house and the QTR panel .
For a $1400 car, why don't you show your kid how to grind the rust, Bondo it, and paint it?
You can do the whole thing for $100 and it will not look perfect, but will be a learning experience.
1986 Bosch Icon Wipers coupe. |
You skipped the part of weld it or is that where the $1400 car comes in?
You wanted a stop gap, right?
Grind it away, and see what you're working with. You might not need to weld new metal since this is not a show car restoration.
1986 Bosch Icon Wipers coupe. Last edited by sugarwood; 07-21-2017 at 08:06 AM.. |
Looks like a decent car. Pay the $650 if you have no skills or tools, otherwise cut it out and weld in new metal, it looks alittle too far gone just to grind and paint.
I was thinking grind and put rust inhibitor then black stone guard sticker like the factory stickers?
