Tired Member
So how bad is this and what do I do now?
![]() ![]() ![]() ![]() I figure the next step is to get the oil lines out of the way and start removing the rust. What tools and techniques should I use to remove the rust?
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
I'm guessing this is your 78 SC? Isn't this a "mid year" where rust is typically an issue? That looks like salt damage to me. You need to follow up with some good pictures of the front pan from underneath and around the batteries, the rocker panels, the longitudinals where the rear torsion bars live, the floor boards and the rear deck. These are areas normally prone to rust. That will give the experts here an idea of the extent of damage. There's a certain point where the towel must be thrown. It's different for everyone. Me and my 72? I'm in it to figure it out, learn what I can, get dirty and get it done. Others may be more prone to farm out the grunt work.
Let me volley this back to you and ask "What do you want to do?" What's your goal? Are you willing to do the work? Are you asking if it's worth tackling? And most importantly, did you read Freddie's 101 series especially about rust removal?
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
dkbautosports.com
pull the front glass i bet you will find some rust under the gasket there . sand blast and weld in some patches . prep and paint .
1980 911 SC
Doing it yourself?
How much time/money do you want to spend? If you don't want to start cutting and welding Stop Rust POR15 could be your friend. Just curious, what does it look like around the bumper shock mounts.
Life's a Beach |
Tired Member
The rocker covers had some good rust under the rubber strip but the rocker panels themselves are solid. the pan is good. (It appears the car was delivered with a good layer of under coating. As the pan is rust free. I want to do as much as I can do/learn. It will remain a daily driver when I'm done so I'm not looking for perfection. Quote:
The bumper shock mounts need some work, too. I'll post pictures of those, soon.
Tired Member
Here are some more pictures:
Front pan... I've got some light surface rust on the gas tank where the under coating peeled away ![]() Rocker panels are solid ![]() ![]() Passenger side bumper shock mount is rough on the top where the dirt/moisture collected. ![]() The bottom of the mount is clean but you can see where the rust on the top has started to penetrate the inside of the trunk.
1980 911 SC
Take a screwdriver and start poking around that shock mount. You will find more rust there than you think. I replaced both sides on my SC. You can take a look here>>>http://forums.pelicanparts.com/paint-bodywork-discussion-forum/498431-front-bumper-shock-support-rust-repair.html
Life's a Beach |
Paper Member
"...did you read Freddie's 101 series especially about rust removal?..."
Was this a thread in this forum? Nevermind. I see the sticky. Duh.........
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
Tired Member
Double Duh... did ya see who created the thread used as the sticky?
Tired Member
Looks like I definitely have to learn how to weld. I'll strip off other parts to get the total scope before diving in. Pictures to follow.
Formerly reformed
Welding is not hard- and doing it correctly simply requires patience, a bit of thinking and proper preparation.
Do you have a MIG unit?
1968 911P (Paperweight) |
Tired Member
I don't have a MIG...yet. Any recommendations?
I have a Miller 180. It takes 220V and is a great little welder. For thinner material - like our cars - I bet you could get away just fine with a Miller 140 which is the 110V version.
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
1980 911 SC
Pick up a few sheets of 20 gauge to practisce on, after that the 16-18 gauge in our cars will seem easy.
Life's a Beach |
Tired Member
A unit that uses gas is a better way to go. Yes, it will cost more, but there will be way less splatter to deal with. I can't say if the actual welds are any better or worse though. Someone with more experience than I will answer on that.
There are a few threads on welders and welding in the 911 section and the off-topic section that would be helpful too. Tom
1980 911 SC
I feel welding thin sheet metal is tricky enough that I want to make the process as simple as possible, and get as much "help" from the welder itself as I can.
Read thru the post, especially some by "Milt", he has some good insight. I can't recall anyone here using a flux core. With sheet metal I want to be able to control everything, heat, wire speed and amount of sheilding gas. I would recomend you buy the best welder you can possibly afford, you will be much happier in the long run. I have used many type of HF tools but when it came time to choose a welder I never even considered them.
Life's a Beach |
Tired Member
While I'm shopping for a Millermatic 140 with gas, I bought a cheap angle grinder and some attachments and went to work.
The tools ![]() Driver's side before ![]() And after ![]() I did this with the wire wheel and grinder. Should I have started with paint remover? Would it have taken off the undercoat? I'm thinking I may be able to get away with patching the holes and covering it with POR-15. Thoughts?
Personally I think you should cut it out and weld in a new piece. If you're hanging on the car for a while you won't regret it. Sourcing a clean replacement and having someone weld it in nicely is not that much of a job given how far you have gone with it already. If you do it this way you can have piece of mind that the job was done right. I'd still POR15 it or some other similar rust treatment as you want to totally cover up bare metal for future nasties. I think you were right not to use paint stripper - chemicals are messy and you run the risk of not cleaning it up properly afterwards. Good luck with it!
My first love - 1993 964 C2 Manual Coupe My second love - 2021 Macan GTS |
Tired Member
Sometimes you hope that your lack of knowledge actually works in your favor and someone will say "there is an easier way." Deep down inside, I knew there wasn't. Just gotta keep telling myself that I can do it.
So, where does one source such parts of a car? And what is the year range I am looking for?
