-   Paint, Bodywork & Detailing Forum (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/)
-   -   SWB inner / outer rocker replacement (http://forums.pelicanparts.com/paint-bodywork-detailing-forum/982968-swb-inner-outer-rocker-replacement.html)
Joscarlang 01-04-2018 06:52 PM
HELLO!!
Been a long time (8 years) since I tore the ol girl apart but now that the divorce is almost final HA! I can finally spend some time with my first love again :eek:
In the midst of a full resto. Bare tub on a rolling dolly (will post pics asap) and just trying to get my head back into this. I'm sure there is a youtube of this but Id like some input from here on this before I have to undo work.
Old outer rockers and inners are cut off. Jack tubes are out and all new parts are in my shop. Doors are off however. So I guess what I'm asking is where do I start?
Do I need the doors and fenders on to start the rocker replacement?
I should mention that I've been working on these cars since age 14 and my day job is a welder/fabricator. Car is in my shop and I have just about every imaginable tool at my disposal...haha I'm guessing that I just utilize measurement data from Porsche, use my lasers etc. I'm about to machine my spacer shims for door and fender gaps on my Bridgeport mill too.
Would love some input!
Joscarlang 01-06-2018 11:43 AM
Originally Posted by Joscarlang (Post 9872865)
HELLO!!
Here aren't a couple of pictures of what I'm looking at. I'm thinking I send it to you out for media Blast the underside and interior first then weld proof primer and repair rockers? https://uploads.tapatalk-cdn.com/201...93178a7fe6.jpghttps://uploads.tapatalk-cdn.com/201...482375bf85.jpghttps://uploads.tapatalk-cdn.com/201...70acf7705a.jpg
Sent from my SM-G955U using Tapatalk
dwiniger 05-22-2018 09:55 AM
'66 911 Rustoration
Yes, you will want to have your door and fender on, when you fit the rocker panel. Door latching, and the seal installed. (flush check). My fender is not bolted at in this picture....so my gap looks large.
...... You know what they say,
Fit, Measure,
Check everything,
then do that 3 times,
before you start welding.
http://forums.pelicanparts.com/uploa...1527007921.jpg
Joscarlang 11-24-2018 07:37 PM
I made some progress this week on my 68's inner rocker panels.
I'm about to move on to the outer but during my preliminary fitment I came across something.
Is the outer rocker panel spot welded along the bottom to the inner?
I found some photos online but i cant really tell.
My car is on its second set of outer rockers and I tore them off so long ago i dont remember if they were welded on the bottom or not.
Does anyone have some photos or could someone take a photo of theirs for me?
Thanks!
Joscarlang 11-24-2018 07:43 PM
Sorry for some reason the one photo wont rotate...
http://forums.pelicanparts.com/uploa...1543117324.jpg
E Sully 01-15-2019 02:59 PM
Might be a little late, but here are good Threads.
http://forums.pelicanparts.com/paint-bodywork-detailing-forum/545166-restoration-my-69-911-a-5.html
DarrylD's Porsche 912 Project Page - Phase 4: Left Outer Rocker Panel Replacement
Joscarlang 01-20-2019 03:31 PM
Thanks!
I'd seen Darryls but not the other. very helpful!
cnielsen 03-21-2019 06:02 AM
One of the best longitudinal threads
DDK - Die Deutschen Klassiker • View topic - Replacing 911 sills and Jacking Points
arbezc 03-18-2023 04:22 AM
I would like to thank cnielsen for the DDK link above. It's the only description I've been able to find that states the original position of a inner rocker panel is behind the leading edge of the rear inner fender panel.
It appears that most DIY restorers are either positioning it on top or cutting the rocker panel & but welding it to the inner fender. Both these methods require less disassembly. There may not be too much difference structurally but its good to know what is factory correct.
