Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Type 1 Upgrade
Considering upgrading my Type 1 Motor 2154 cc in my 57 356 Outlaw Coupe. Anyone know of an engine builder in the W. Pa. area. May swap motor with a polo motor. Already have 901 transmission and oil cooler, disc brakes. Anyone know of a mechanic or builder who has installed a Polo motor on the E. Coast.
Old 11-09-2018, 06:11 PM
We are considering the same for our '64 SC coupe. The Porsche engine is getting tired and a bored/stroke VW might be the answer. There must be somebody in the Western NY or PA area who is into hot VW's.
Old 12-24-2018, 11:37 AM
Puny Bird
Mark Henry's Avatar
Another option is a T4 engine using a DTM fan shroud, a 914 2.0 is 100hp stock. My '67 bug I have T4 2600cc 180hp, 102mm Nickies, 78mm crank and mod T1 H-beam rods, cam, FI, etc with a 911 (901) and 914/4 gearing. I have 20K miles on this engine combo.
Engine about $10K in parts, say $18-20K pro built/installed. You can build a smaller 160hp 2276cc cheaper, but any bigger than 96mm iron cylinders you need Nickies.
I put almost the exact same engine with weber 44mm IDF's in a 356 flared kit, smokin' torque monster.
Not cheap but way less than a Polo.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 12-26-2018, 07:29 AM
Puny Bird
Mark Henry's Avatar
The T1 vs T4 in a nutshell. Think small block vs big block.
T1 small block, way more parts, cheap performance parts (also lots of cheaper junk), can triple the power, 50 to 150hp* reliability with the right parts. Engine like a on/off switch, gets up to speed fast but not much torque at speed.
T4 big block, less parts available, more expensive, double the HP max 95 to 180hp*. Performance engine is torque monster at speed.
* Both can be made with more HP, the numbers I give are for reasonably longlife performance engines. Plus when hearing builders HP#'s claims keep in mind there's a lot of embellishment or shall we say "wishful thinking". Often builder AND client share equal blame with this wishful POV.
Old 12-26-2018, 08:05 AM
Does the engine bay or transmission connection easier with a T1 or T4? I am considering a T1 for simplicity sake and desire a little more kick than the stock SC motor.
Old 01-29-2019, 04:46 PM
Puny Bird
Mark Henry's Avatar
The DTM kit and conversion flywheel bolts right up to a type one transmission.
The DTM turns the T4 into an upright fan, generator and fan used is type 1, it will fit a T4 engine anywhere a T1 engine will go.
Below is a 2056cc, 914 2.0 heads, CSP SS header, 40mm weber IDF's WEB camshaft, T1 pump, full flow oiling and the DTM is the fan shroud. About 130 HP maybe a bit more. Compared to the T1 it's a torque monster, this engine is going into a beetle.
If on low budget a stock type 4 can be used, with 914 2.0 heads and header still give you 100-110hp, stock and fairly bulletproof.
One year only the '76 912 used the T4 engine.
Old 01-29-2019, 05:07 PM
Tags
outlaw , polo , type 1
