Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Question Removing deep rust
What is the best way to remove all rust from the doors? I have been using 24 grit paper on a grinder. this has cleaned up most the rust, but, I still have deep pits that won't clean up.
thanks,
Shane
Old 08-05-2001, 02:16 PM
Post
Deep surface rust pits. The kind you will never get out with a grinder or sander. I was told to try muriatic acid. then coat with POR-15.
Old 08-09-2001, 04:34 AM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Post
Use OSPHO aka Metal prep. OSPHO can be puchased at True Value. Metal Prep is at the Welding supply store. Apply with a brush and let dry,then prep and paint. Steve
Old 08-09-2001, 08:27 AM
