Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Lightbulb 912/356 rotors, same?
Are the rear rotors on the disc braked 356's the same as the rear rotors on the early 912's?
The rotors on my 912 have a circular opening in the hub mounting surface (center). The 356 appears to have scallops cut out in-between the stud holes, but otherwise looks the same.
Whats the difference?
Dave A
Old 09-21-2001, 10:49 PM
Post
The C/SC rotors and the 912 rotors are interchangable as are the early 911 rotors.
Kelly
Old 09-22-2001, 12:26 PM
Senior Member
Post
Hello
AFIR the 356/912 rear rotors are the same.
The cutouts were needed to clear the oiltube cuming out from the lining protector.
The 356 have a swingaxle witch has the outer bering in oil. A failure would oil up the drum so there is a inner catchring with a tube going outside.
Roland
Old 09-23-2001, 04:14 AM
