| Registered |  912/356 rotors, same?
			Are the rear rotors on the disc braked 356's the same as the rear rotors on the early 912's? The rotors on my 912 have a circular opening in the hub mounting surface (center). The 356 appears to have scallops cut out in-between the stud holes, but otherwise looks the same. Whats the difference? Dave A | ||
|  09-21-2001, 09:49 PM |
| Registered |
			The C/SC rotors and the 912 rotors are interchangable as are the early 911 rotors. Kelly | ||
|  09-22-2001, 11:26 AM |
| Senior Member Join Date: Nov 2000 Location: Stuttgart FRG
			Hello AFIR the 356/912 rear rotors are the same. The cutouts were needed to clear the oiltube cuming out from the lining protector. The 356 have a swingaxle witch has the outer bering in oil. A failure would oil up the drum so there is a inner catchring with a tube going outside. Roland | ||
|  09-23-2001, 03:14 AM |
