Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Valve Adjustment Difficulty
Greetings.
I am adjusting the valves on my 1963 Cab for my first time. Cylinder number 3 exhaust valve is pressed tight to the valve stem. I loosened the holding nut and began turning the adjustment screw counter-clockwise and it stopped after several turns without opening a gap to make an adjustment. Intake valve on #3 adjusted OK as well as both valves on cylinder #4.
Suggestions?
Thanks,
David L.
Old 04-03-2023, 03:32 PM
Originally Posted by DavidLeavell View Post
Greetings.
Suggestions?
Thanks,
David L.
are you absolutely sure you are at TDC?
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2025 Ranger Raptor
Old 04-06-2023, 03:22 PM
