Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
dgagne's Avatar
Rebuilt 912 engine
A 356 I am considering buying comes with the original engine as well as a rebuilt 912 engine with big bore kit and 356 sheet metal on it. Any thoughts on what the 912 engine is worth? I have no other details.
I was thinking around $2000-3000 Canadian.
Thanks,
Derek
1989 964 Carrera 4 Coupe
Old 04-25-2005, 09:30 PM
id10t's Avatar
A running engine is worth probably 5k USD... assuming it is in good shape. Of course, a rebuild on a core will run you around 5 or 6 thou as well...
Old 04-26-2005, 06:14 AM
Banned
snowman's Avatar
So what do you all think an 8000 rpm 912 that puts out a dyno measured 180 HP at 7800 RPM, has Carillo rods, Scat billet crank and Shasta Pistons, fully tricked out heads is worth??
Old 04-28-2005, 07:54 PM
dgagne's Avatar
Not much to me, no idea what you are talking about!
Old 04-28-2005, 10:29 PM
id10t's Avatar
After about 100 hours? Whatever a core suitable for rebuilding would be
Old 04-29-2005, 05:58 AM
Banned
snowman's Avatar
Cores go for about $400 US don't they? A 912 in bad shape with running, reasonable shape engine should be about $2500 US THerefore you should be able to get a running 912 engine for around $1500 to $2000
Old 04-29-2005, 02:11 PM
