Rebuilt 912 engine
A 356 I am considering buying comes with the original engine as well as a rebuilt 912 engine with big bore kit and 356 sheet metal on it. Any thoughts on what the 912 engine is worth? I have no other details.
I was thinking around $2000-3000 Canadian. Thanks, Derek
1989 964 Carrera 4 Coupe |
A running engine is worth probably 5k USD... assuming it is in good shape. Of course, a rebuild on a core will run you around 5 or 6 thou as well...
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Banned
So what do you all think an 8000 rpm 912 that puts out a dyno measured 180 HP at 7800 RPM, has Carillo rods, Scat billet crank and Shasta Pistons, fully tricked out heads is worth??
Not much to me, no idea what you are talking about!
After about 100 hours? Whatever a core suitable for rebuilding would be
Banned
Cores go for about $400 US don't they? A 912 in bad shape with running, reasonable shape engine should be about $2500 US THerefore you should be able to get a running 912 engine for around $1500 to $2000
Thread Tools | |
Rate This Thread | |
